Does anybody drive on FF mode at ST185?
Postby mison » Thu Feb 02, 2006 7:34 am
Is it possible?
mison
Postby OlyST185 » Thu Feb 02, 2006 10:04 am
i dont see the point of doing this, it is doable, but not recommanded by anyone nor toyota.
-Oly (Montreal)
3SGTE'S POWER, 4WD SUPREMACY
[img]http://olyst185.multimania.com/turbo4wd.jpg[/img]
-ST185 1990 Black. RC/CS Conv.
OlyST185
Postby 98RACE » Thu Feb 02, 2006 12:42 pm
We have tryed to tractionize tires in FF mode but we had a strange clicking noise so we stoped. :shrug:
98RACE
Postby mison » Thu Feb 02, 2006 2:05 pm
I want go to dyno,but nearest dyno for 4x4 is pretty far. I think measure torque only at FF.
mison
Postby celicat93 » Thu Feb 02, 2006 2:27 pm
you're not even supposed to tow in FF mode, drive in this manner at your own risk. Why the hell do all these people ask about this anyway? You want a FWD Celica? They make them. Put a turbo on a GT and knock yourself out.
celicat93
Postby SuperWhite92 » Thu Feb 02, 2006 2:28 pm
mison wrote:I want go to dyno,but nearest dyno for 4x4 is pretty far. I think measure torque only at FF.
You can dyno in 2WD mode for sure, that's the reason it's there.
Drive to the shop in 4WD, when you get there, switch to 2WD and dyno, then switch back before you leave the dyno shop.
Shaun
SuperWhite92
Postby mison » Thu Feb 02, 2006 2:41 pm
But I read, I can´t reach 40-60 km/h at FF mode.. I can´t do something wrong. I will measure "power" with GPS something, I do not name it in English :o) this Sunday. I still think, my car do not run correct. It has not power I think.
mison
Postby SuperWhite92 » Thu Feb 02, 2006 2:45 pm
Definately fix your car first. If something can break on the dyno, it will
Shaun
SuperWhite92
Postby jprine01 » Thu Feb 02, 2006 2:49 pm
On the dyno people have gone people go allot faster then 60km/hr in FF mode. When doing FF mode make sure you put the bolt back in to lock it in place. One guy changed it to FF mode but didn't bolt the lever back down, while on the dyno running the car the lever moved and the trans exploded.
jprine01
Postby mison » Thu Feb 02, 2006 3:00 pm
But I don´t know, if my car is ok or not. I did bought it, and it was not run, I do not drive ST185 before..Some peoples here said, it is ok, but for me it seems to be slow and with no power :shrug:
mison
Postby toayoztan » Thu Feb 02, 2006 3:23 pm
I thought if you put in FF mode, you're not supposed to move the rear wheels (hence, dyno only, not driving) because something about messing up the transfer/rear diff.
Secondly, you're not supposed to tow on two wheels (rear or front), which is why you would need a flat bed.
I don't know why exactly, i know it's vague. maybe someone can vouch.
Okay here to read from the 1990 BGB provided by celicatech - http://www.celicatech.com/imagearchive/ ... T/MT-4.jpg
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby jprine01 » Thu Feb 02, 2006 4:07 pm
You actually can tow on 2 wheels according to the owners manual in the glove box. The other 2 wheels just have to be up in the air or in some other way able to spin freely. Although I wouldn't tow it like that.
jprine01
Re: Does anybody drive on FF mode at ST185?
Postby Rallly » Tue Dec 22, 2015 10:55 pm
Why can't we drive it in ff mode??
Rallly
Postby FC Zach » Wed Dec 23, 2015 2:12 am
For dyno testing only, the two wheel setting can not support constant use and damage to transmission will occur if left in that position. Also, I believe I read that only a certain amount of power from the engine can be used while on the dyno.
Basically, if you are not sure and are not a Toyota tech then it should be left alone.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby underscore » Wed Dec 23, 2015 3:22 pm
There's a thread on here with all the details about it, but long story short DO NOT DO IT or you will blow things up in your trans and have a very bad time. I believe the main issue comes from the rear wheels turning, thus causing the driveshaft to turn, thus causing the rear output side of the center diff to be turning when it's not supposed to be. If you removed the driveshaft you *might* be able to do it, but then you may damage your rear diff, and honestly who the hell buys an AWD car and then want to drive it around in FWD?
