Caldina swap issues
Caldina swap issues
Postby maroon_185 » Tue Aug 10, 2004 12:39 am
At the end of this school year when I graduate I am basically getting about 5k thrown at me for whatever I want. So I figured I might look into doing a swap to a more powerful engine.
The caldina 3s was an idea and I was wondering what Issue might arrise
by using it.
Thanks in advance
Chris Fowler
1990 maroon 185 (rc swapped)
1991 red mr2 (3s swap coming soon) Dads
maroon_185
Postby alltracman78 » Tue Aug 10, 2004 12:44 am
Just a shot in the dark, but you might be better off spending it elsewhere than the newer engine. Off the top of my head, added pwr comes from 9.0-1 comp, better turbo, ecu, and no afm. All of which you can take care of with the 5k (-maybe the 9.0-1). That will give you alot less hassle, too.
Postby killer_siller » Tue Aug 10, 2004 1:20 am
it really isn't worth going for the caldina engine. people have done alot more for alot less with stock engines.
if you are really up for a swap call up toysport (www.toysport.com), look at the engines they offer. ive seen a 3sgte from them that reliably (i mean toyota daily driver reliably) put out 425hp.
...if only i can remember where i found it.
killer_siller
Postby maroon_185 » Tue Aug 10, 2004 1:52 am
alright thanks I will just rebuild and make it better then swap
Chris Fowler
maroon_185
