Battery size
Battery size
Postby MaskedMan » Sat May 27, 2006 12:09 am
Hey i have a 91 st185 and it came with the battery relocated in the back. I was having problems with this and decided to move it back to the front. I have the stock battery tie down, but the battery is too tall, and cannot bolt the tie down in. Can anyone tell me what kind of battery is the stock size?
MaskedMan
Postby Gary » Sat May 27, 2006 1:07 am
BCI Group size 35
L x W x H = 230 x 175 x 225 mm (9 1/16 x 6 7/8 x 8 7/8 inch)
93 ST185
Gary
Postby crazy_russian » Tue May 30, 2006 2:05 pm
Gary, where do you find this info? I need to know st165 stock battery size.
88 ST165
crazy_russian
Postby Gary » Wed May 31, 2006 12:23 am
You just need to find out what group size ST165's battery is.
Then go here
http://www.rtpnet.org/teaa/bcigroup.html
93 ST185
Gary
Re: Battery size
Postby boogiedown5150 » Wed May 31, 2006 3:09 am
MaskedMan wrote:Hey i have a 91 st185 and it came with the battery relocated in the back. I was having problems with this and decided to move it back to the front. I have the stock battery tie down, but the battery is too tall, and cannot bolt the tie down in. Can anyone tell me what kind of battery is the stock size?
Hey bro its been a while...so other than your battery problem how is the car doing? Get her running good yet?
Dave
1990 ST185-SOLD
1990 GTS (Daily)
boogiedown5150
Re: Battery size
Postby dkenned1 » Mon May 08, 2017 1:40 am
Just in case this helps anyone else.
The 35 group size is smaller, which you may or may not want but it causes a lot of play in the battery tie down.
I measured the battery tray and its for a 24F no matter what Toyota's repair manual says this is the right factory size.
And yes its a pretty tight squeeze in there but it fits the mount and the tray perfectly, everything is now secure and where it should be
dkenned1
Users browsing this forum: Google Adsense [Bot] and 3 guests
