Which NGK?
Which NGK?
Postby Felix » Tue Aug 10, 2004 3:32 am
I'm going to replace the plugs w/ NGK's. I was gonna go ahead and use BKR7E's...but someone posted that unless you are going over stock boost, you should stick with the stock NGK BKR6E. Are there any problems with using the 7's on a stock AT?. Just wondering.
Gary-you'll probably post on here, so thanks for all your help!
1992 Celica ST 5Speed "Midnite Black"
1991 MR-2 GT 5Speed T-Tops "Arrest Me Red"
2005 Scion tC 5Speedd Flint Mica Gray "MY XTC"
-We Miss You- 1990 Celica All-Trac Turbo (G/F's) (Sold)
Felix
Postby Gary » Tue Aug 10, 2004 3:54 am
Putting a colder plug in an engine which doesn't require a colder grade sometimes causes difficult cold starting and poor running at low rpm.
If you want to keep the stock boost, BKR6E should do the job.
93 ST185
Gary
Postby turbo4wd » Tue Aug 10, 2004 4:05 am
I've personally experienced this extended crank that Gary refers to.. It happens a lot when the engine is cold, but seems to get better once youve run the car..
Like Gary mentioned, if you're running stock or close to stock boost levels, I wouldnt worry about the stock plugs/heat range.. They'll work just fine..
Dan
Undercover Moderator
turbo4wd
Postby jspeccelica » Wed Aug 11, 2004 1:18 pm
What about the differences between the NGK Copper Spark Plugs BKR7E, and the NGK Iridium Spark Plugs BCPR7EIX , I know the copper plugs are only 2 bucks a pop and the iridium is 40 bucks a pop, but as far as cooling goes are they the same? and what are there lifespans? is it worth the extra 38 dollars so you don't have to change them every 3000 miles?
Red '91 ST185
I've spent most of my money on cars and women, the rest I've just wasted...
jspeccelica
Location: Bay St. Louis, Mississippi/ Mooresville, North Carolina
Postby Gary » Wed Aug 11, 2004 5:34 pm
Copper conducts electricity better than Iridium.
Iridium sure last longer.
However, changing the plugs every oil change is not a bad idea.
At least you can early detect if anything's gone bad.
You car will have fresh plugs every 2500-3000 miles. :wink:
93 ST185
Gary
