car wont start
car wont start
Postby alltracshoak » Tue Jun 27, 2006 6:06 pm
after blowing the i think AMT 100a fuse, it wont start anymore. i was going to get on the freeway and stepped on it, the fuse blew on my and my blitz turbo timer computer was fried too.after replacing it, it would crank but then wouldnt start. check my efi fuse already, its good, any suggestion?
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby mototebok » Tue Jun 27, 2006 9:19 pm
Odd that the 100A would blow, if it did...replace it.
I would check the 40 and 60A ones that are similar to the 100. I forget which one exactly will especially cause this, but I suspect that you have a blown fuse still.
-Adam
'88 Alltrac .... Got a shiny new turbo
'94 RX7 .... Other money black hole
'00 ZX6R .... Lime Green Speed Machine
mototebok
Postby alltracshoak » Wed Jun 28, 2006 5:10 pm
yeah i look.if the 100a fuse blow, nothing inside my cluster would work.it wouldnt even crank. now that i replaced the fuse, it'll crank but then wouldnt catch on and start. any other possibility that i might forgot to check?
current:
90 st185
GT4 AWD
alltracshoak
Postby mototebok » Thu Jun 29, 2006 11:36 am
Are there any codes stored in the ecu?
-Adam
mototebok
Postby alltracshoak » Thu Jun 29, 2006 4:27 pm
right now, if i short the terminal, the cel doesnt come on anymore.ill use the other post to help me out about the cel light. the problem is is that it wont start. ill take the cluster out and see if the bulb went out or not, ill replace it and see if it throws any error code.
current:
90 st185
GT4 AWD
alltracshoak
Postby Mafix » Thu Jun 29, 2006 5:00 pm
the only rewason i've seen the fuse blow is the alternator shorted. try disconnecting it.
Built Gen 1 3SGTE,Megan,Autopower,Forza,Precision,Haltech,COP,Racepak,FMIC,Nitto,CRW axles,Quaife,V6 trans,Competition Clutch,Fidanza,Moroso,ST,370whp,340tq
Sponsors: Midas, SRT, Paradise Racing, CRW, ST162.net
Postby alltracshoak » Thu Jun 29, 2006 5:29 pm
ok. ill try that in a bit, i just checked my cluster and the cel lightbulb isnt blow. could it be that my ecu is fried?also, my 100a fuse doesnt blow anymore.
current:
90 st185
GT4 AWD
alltracshoak
Postby Mafix » Thu Jun 29, 2006 6:37 pm
well, you really need to find why it blew...that fuze doesn't just go poof. and yes if it fried you TT then why couldn't it fry you comp? radio still good?
Postby alltracshoak » Fri Jun 30, 2006 2:55 am
i dont know why it blew. here's my story to tell. i was getting on the freeway, i stepped on it and i guess the fuse just blew so i slow down and pulled over. while pullin over, i smelt a burnt which was my turbo timer . after that, called the tow truck and tow it to my house and replace the fuse and never started again. i tried to see if there's any codes but then the cel doesnt come on anymore and i just dont know where to look at after checking the cel if it blew too or not.
sorry to make it so long.
current:
90 st185
GT4 AWD
alltracshoak
Postby alltracshoak » Mon Jul 03, 2006 8:47 pm
alright, now i notice that there's no electric going through my spark plug wires. also, it seems like my there's no fuel delivering to my engine too. if anyone can help to locate my problem please help. i want to find out first and fix it before having to take the other suggestion which take it to the shop.
current:
90 st185
GT4 AWD
alltracshoak
Postby 1BADGT4 » Mon Jul 03, 2006 8:59 pm
I'm no expert but blowing a 100amp fuse is a big deal.
So you replaced the fuse, its still good and nothing comes on?
UT2 (SCW) Chan - Oakland, CA
04 Duc Monster DS
400BHP @ 20#, low 12s
1BADGT4
Postby alltracshoak » Mon Jul 03, 2006 9:04 pm
yeah, right now i got the fuse on. everything seems to work except no spark going through spark plug wires,when i turn onto ignition, there's no fuel too.
current:
90 st185
GT4 AWD
alltracshoak
Postby 2RM » Mon Jul 03, 2006 9:25 pm
For the fuel you can short Fp and B+ terminals in the check connector that will run the FP constantly Check your ECU and try to swap it with anotheone ECU should be fine because it got a separate fuse I think a 15amp in the engine bay fuse box near the battary so the chances of blowing it are slim
2RM
Postby alltracshoak » Mon Jul 03, 2006 11:52 pm
there's no one near to lend me their ecu to test it out so ill probably have it taken to the shop and see if it's the ecu or something else. about shorting the fp and b+ terminals, ill try that to see if it works as well.
current:
90 st185
GT4 AWD
alltracshoak
Postby alltracshoak » Tue Jul 04, 2006 12:28 am
ok. it seems like there's no power even at my diagnosis box. when i short it nothing happen. i must of burnt something besides my 100a fuse. just hoping not my ecu. well from here on, i guess im going to throw down the towel and take it to a local mechanic that i have been takin it to for 2 times now. see if he can help me out then.
current:
90 st185
GT4 AWD
alltracshoak
