st185 jdm compared to the usdm 3sgte?
Postby gpmarzan » Tue Aug 29, 2006 2:23 am
903SGTE wrote:so all the acessories are in the same place? what about the speedo cable in the trans?
same, same. like stated, only major differences are egr and ecu
Patrick M.
st165
gpmarzan
Postby Gary » Tue Aug 29, 2006 2:58 am
The JDM transmission has electronic speedo sensor.
The US one has mechanical speedo sensor (cable driven)
However, you can swap the electronic sensor on the JDM with the mechanical sensor from your US one.
93 ST185
Gary
Postby 903SGTE » Tue Aug 29, 2006 11:42 am
thanks for all the help guys! i think im going to order the jdm st185 engine! is there anything i should do to the jdm engine before installing it in the car? someone a while back, i think on the supra forum, mentioned that when they install a jdm engine they always replace the engine bearings due to the salt water during the transportation eating away at them?? does that sound right? thanks again!
903SGTE
Postby Sleeka_89 » Tue Aug 29, 2006 1:11 pm
yep all the same
A man who shoveled snow for an hour to clear a space for his car during a blizzard in Chicago returned with his vehicle to find a woman had taken the space. Understandably, he shot her.
Sleeka_89
Postby jlspec » Tue Aug 29, 2006 3:12 pm
Since the engine is out, Get a performance clutch, change all hoses and gaskets (The head gasket is optional depending on what your planning),Clean the dam thing, and you might want to get the transmission check or replace to save you Major headaches later on.
jlspec
Postby jlspec » Tue Aug 29, 2006 3:15 pm
Opps, at the very bottom I ment "replace synchros with dual"
jlspec
Postby 903SGTE » Tue Aug 29, 2006 6:03 pm
the engine i will be getting comes with the trans on it already. i was doing some research and found that some jdm transmissions have a diffrent final drive gear? u.s has 3.933 and jdm might have 4.285.. how do i know that this trans will work with my rear end diffrential gearing?? i dont want to isntall this whole thing and then find out i cant drive it due to the diffrence in gearing from the front to the rear.. maybe though due to the transfer case this wouldnt be an issue?? anyone have any ideas on this?? thanks
903SGTE
Postby vip09 » Sat Sep 02, 2006 6:38 pm
My friend just bought a JDM 3sgte front clip. It came with TRD plug wires.. I tried to put them on my usdm engine but the plugs on the wires where they plug into the distributor and coil were way to big.. wouldn't even fit in there.
vip09
Postby theUNYTEDone » Sat Sep 02, 2006 8:54 pm
903SGTE wrote:the engine i will be getting comes with the trans on it already. i was doing some research and found that some jdm transmissions have a diffrent final drive gear? u.s has 3.933 and jdm might have 4.285.. how do i know that this trans will work with my rear end diffrential gearing?? i dont want to isntall this whole thing and then find out i cant drive it due to the diffrence in gearing from the front to the rear.. maybe though due to the transfer case this wouldnt be an issue?? anyone have any ideas on this?? thanks
i thought only the ST185CS had a different final drive?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Re: st185 jdm compared to the usdm 3sgte?
Postby celi703 » Thu Mar 31, 2016 9:50 pm
Sorry for reviving this thread but have a question. I purchased a jdm st185 engine to put in my alltrac. I know it is plug and play expect no egr system. Also the same usdm harness can be used. Is a jdm ecu necessary or the same usdm ecu be used. The reason I ask because the engine is in and it would not start. Anyone have any suggestions? I hope it’s not a fuel pump issue because the car started fine before the swap.
90 ST185 3E5
14 FB6 TW
celi703
Postby DeeCee » Thu Mar 31, 2016 10:26 pm
Holy post dredge! I would recommend starting a new thread next time and referencing this thread with a URL link.
From memory the JDM and USDM ECU's have different pin outs so that matching with a USDM harness could be the issue. I would do a wire trace to ensure that you know which wire is the correct wire to the correct ECU pin.
There are various threads with ECU pinouts and wire colour coding you can use to diagnose the wiring.
DeeCee
Postby underscore » Fri Apr 01, 2016 12:42 am
If you're using a USDM ECU, harness, MAF etc then it should be fine. What do you mean by would not start? Does it at least crank?
