Deleted.
B BoostedBlueToyotas New member Oct 11, 2004 #2 Check if your intake hose (one attaching to the turbo) is cracked at the point that it connects to the turbo. If it is then it is probably leaking blowby oil thru the crack after you turn off the motor. Just get a new hose and/or a catchcan.
