High Idle w/ AC
High Idle w/ AC
Postby jspeccelica » Wed Aug 11, 2004 7:34 pm
I know that when the compressor comes on, the car usually tends to up the idle a little to get a little more juice from it, when I idle w/o my AC on she idles fine at around 800-900 rpm, but once I turn on the AC it kicks up to 1900 rpm! Is this normal? It wasn't the case in my '91 GT...
Red '91 ST185
I've spent most of my money on cars and women, the rest I've just wasted...
jspeccelica
Location: Bay St. Louis, Mississippi/ Mooresville, North Carolina
Postby Gary » Wed Aug 11, 2004 7:43 pm
Mine goes up around 1700 rpm. (I have vac leak. :x )
There is an AC idle up control valve on the upper right corner of the engine above the distributor. It looks like adjustable screw with spring. You can adjust that.
See pic here
Click on image for larger pic.
93 ST185
Gary
Re: High Idle w/ AC
Postby SLC Punk » Wed Aug 11, 2004 7:43 pm
jspeccelica wrote:I know that when the compressor comes on, the car usually tends to up the idle a little to get a little more juice from it, when I idle w/o my AC on she idles fine at around 800-900 rpm, but once I turn on the AC it kicks up to 1900 rpm! Is this normal? It wasn't the case in my '91 GT...
Mine does that too. I know that there is an adjustment, but I don't know what it is supposed to be at.
-Travis
1992 ST185
2014 4Runner Trail
2015 Lexus GX460
1978 F250
SLC Punk
Postby jspeccelica » Wed Aug 11, 2004 7:46 pm
I see said the blind man... thanks
Red '91 ST185
jspeccelica
Postby Gary » Wed Aug 11, 2004 7:47 pm
The AC idle up controller (AC-VSV) raises the idle by letting air bypass the throttle when the AC compressor puts load on idling engine. I don't remember what stock setting is. Gotta check with the BGB.
93 ST185
Gary
Postby zblu81 » Wed Aug 11, 2004 11:12 pm
i'm at 700rpm with warmed up engine no A/C. then 1200 with A/C on.
[b][/b]Greg
Lansing, MI
'92 turbo All-Trac
3" Exhaust, RC intercooler, ATS TD06-20g, stage2 clutch
zblu81
Postby dlek00 » Thu Aug 12, 2004 12:43 am
yeah, mine jumps up to 1300 rpm's
Daniel Lek
Chicago, IL
2005 Civic EX
email: dlek00@yahoo.com
dlek00
