CelicaAllTrac92
One of my rear turn signals quit working, but the bulb is fine. The wiring that I can see looks fine. Where in the world do I look next?
I don't know. It still clicks and makes the lights flash. It's only the left rear signal that doesn't work. If I turn on the hazards it clicks normally, but that light doesn't work.InitialD93":b7go6im1 said:that would probably be the flasher relay... in the driverside kick pannel
