High pitch whistle when warmed up.
Postby HWNST185 » Wed May 05, 2010 10:17 pm
I couldn't find anything related to this by searching. I have this high pitch whistle when my engine is warm and pulling full vacuum. The sound is coming from around the throttle body or intake manifold. I have replaced a bunch of the vacuum lines in that area but it still does it. Last time I smoked the car there were no leaks. I have a FMIC and no cruise control if that helps any. Thanks in advance for any input, this is getting really annoying when driving around.
HWNST185
Re: High pitch whistle when warmed up.
Postby 5thgenbliss » Wed May 05, 2010 11:50 pm
+1 on this condition. I have developed the same hi pitched whistle when warm coming from the intake manifold/TB area. this is during idle, once the rpm raises to above 1700rpm it goes away.
I haven't found the problem yet either.
anyone have an idea on this 3SGTE issue :(
I will add, other, than the annoying whistling, there doesn't seem to have any adverse performance or drive-ability effects.
Boosting with the '92 GT4 RC
5thgenbliss
Postby Corey » Thu May 06, 2010 1:41 am
I've heard the same thing from time to time :shrug:
Corey
Images: 50
Postby MWP » Thu May 06, 2010 2:01 am
Yep, i get it also.
Seems to happen for a week or so, then go away for a few weeks.
A lot of my vac lines have been changed from the factory, and has a different idle air control valve, so you guys can rule those things out.
Postby 5thgenbliss » Thu May 06, 2010 3:41 am
i was thinking of replacing the Idle air control valve because i'm starting to have a bit of an idling problem that hasn't gone away either. You're probably right, its not related to the whistling.
5thgenbliss
Postby MWP » Thu May 06, 2010 8:27 am
To me it sounded more like the noise was coming from the head... so maybe a camshaft bearing.
Either way, im going to ignore it until it becomes bad enough that i can work out where it is coming from.
Postby Mafix » Thu May 06, 2010 12:32 pm
mine was a vacuum leak. just got done with that mess.
Postby gt4tified » Fri May 07, 2010 6:56 pm
Check your a/c idle up vsv all of you.
gt4tified
Images: 5
Postby HWNST185 » Fri May 07, 2010 11:59 pm
Hmm, just changed the A/C idle up VSV and it did it before that too. My friend suggested it might be from the TB, so I think changing the last two hoses and cleaning the TB will be my next move. Thanks for the info on the A/C.
HWNST185
Postby 5thgenbliss » Sat May 08, 2010 5:57 am
brand new AC idle up valve, but i'll fondle it just for good measure :twisted: Cleaned out throttle body and I have all new sili hoses. (not so say new means no trouble) I guess its just a process of elimination with these annoying things. My bet is a small vaccuum leak somewhere.
5thgenbliss
Postby HWNST185 » Sun May 09, 2010 8:56 pm
I cleaned the TB and resealed the intercooler pipe fitting on the TB and so far so good after driving around the neighborhood for a while.
HWNST185
Postby Corey » Mon May 10, 2010 4:48 pm
I drove my car yesterday. And found that the whistle stops once the car is warmed up, or when the engine RPM is higher than idle.
I've had my TB off in the past and have cleaned it out with compressed air. I also have new silicone hoses everywhere. Maybe the TB metal gasket needs to be replaced?
Corey
Images: 50
Postby 5thgenbliss » Mon May 10, 2010 9:09 pm
my whistling starts when the car is warm at idle. when the rpm is higher than idle it goes away.
5thgenbliss
Postby Darkstar20999 » Mon May 10, 2010 9:55 pm
:roll: i have to join this club to lol dnt know what it is but i have the same high pitch whistle sound its weird took it to a few ppl and seems the older guys cant hear it but alot of my friends that are younger can hear it just as easy as me lol so what is it lol
Darkstar20999
Postby HWNST185 » Tue May 11, 2010 6:15 pm
Whistle came back yesterday. :x :shrug:
HWNST185
