Radiator Fan not working
Postby celica st165 » Sat May 22, 2010 7:02 am
Hi,
Can anyone tell me why my radiator fan isn't working? I changed, the water pump, timing belt and all the other parts. But now my fan won't turn on, i tried to connect it straight on the battery and it works, but not when connected like it should..
Please help me :D
celica st165
Re: Radiator Fan not working
Postby Pechin0351 » Sat May 22, 2010 12:08 pm
Did you check the sensor on the bottom passenger side of the radiator? That sensor controls when the rad fan comes on. There is also a relay and fuse to check...
I do solemnly swear that I will support and defend the Constitution of the United States of America against all enemies, foreign and domestic; that I will bear true faith and allegiance to the same. So help me god!
Pechin0351
Postby celica st165 » Sat May 22, 2010 1:00 pm
i wasn't sure were it was located. How do i check it? I have a other ST165's so parts enough
Thanks
celica st165
Postby Pechin0351 » Sat May 22, 2010 1:28 pm
Ok well at the risk of backwards instructions... I believe if the sensor is shorted (no resistance) then your radiator fan will not come on... When I got my car the plug side of that sensor had been twisted internally and the wires shorted causing the fan not to come on...
Pechin0351
Postby celica st165 » Sun May 23, 2010 7:39 am
i placed another sensor, but still nothing, so i think the wires are bad. Is there a way to test it? Connect both wires together maybe?
celica st165
Postby Pechin0351 » Sun May 23, 2010 1:19 pm
Well, without taking the entire circuit into consideration, you could take a multimeter and test the connector on the wiring harness side and see if there is any resistance, if you get zero ohms then most likely there is a short... Have you checked your relay yet to see if it is operating properly? You can put a little jumper wire in place of the relay and see if the fan cranks on that will atleast give you an idea of where to start fixing things... But with the relay if you apply 12v and it clicks then most likely its good I would also make sure that your contacts in your fan plug are clean, as well as the water temp sensor in the radiator...
Pechin0351
Postby celica st165 » Sun May 23, 2010 2:53 pm
problem solved, bought 2 brand new relay's but seems that one is bad and that was the problem.
Fan now works just fine, let's hope it keeps going fine...
celica st165
Postby 88gt4DE » Mon May 23, 2011 1:54 am
Im now having similar issues ... Only poked around with it a little on the road. unplugged the water temp sensor at bottom of radiator so I could get her home. Stays cool on the highway just fine but the radiator fan wont turn on when it heats up at idle. Already replaced water temp sensor in radiator. Going to check fan and replace relays next and see what happens ... :shrug:
Postby Awesome-Trac » Fri Aug 21, 2015 7:37 pm
Thread Revive: do you guys know which relay controls the radiator fan? I see a AC fan and fan relay 1 and relay 2
•Daniel
Awesome-Trac
Postby zaluss » Fri Aug 21, 2015 10:05 pm
Awesome-Trac wrote:Thread Revive: do you guys know which relay controls the radiator fan? I see a AC fan and fan relay 1 and relay 2
Top fusebox (3SFE and 3SGTE gen1 share the same fusebox). Radiator Fan Relay No.1
zaluss
Postby Awesome-Trac » Fri Aug 21, 2015 10:41 pm
Is there anyway to jump the circuit to get the fans to turn on?
•Daniel
Awesome-Trac
Postby zaluss » Fri Aug 21, 2015 10:52 pm
Awesome-Trac wrote:Is there anyway to jump the circuit to get the fans to turn on?
What are you trying to do? You can pull the plug on the coolant temp sensor on the bottom of the radiator. This will keep the fans constantly running.
zaluss
Postby Awesome-Trac » Sat Aug 22, 2015 12:58 am
So the fan in front of the car is running consistently dues to the coolent temp sensor But the fan inside the engine isn't turning on at all so as of right now only one fan is keeping the engine as cool as possible
•Daniel
Awesome-Trac
Postby zaluss » Sat Aug 22, 2015 2:04 am
Gotcha. Unplug the harness plug connected to the fan that isn't working and check for 12v at the harness with the key turned to ON with the coolant temp sensor unplugged. If there is no 12v, then you know its either a relay or wiring issue. If there is 12v, the fan is likely done.
zaluss
