ST165 Valve Cover Gasket Replacement
Postby dorichimpsak » Thu Feb 09, 2012 5:19 pm
I'm in the process and will be doing a full write up soon. So far I had to take off the ic, throttle body and coolant lines and sensors to tb, harness connections to alternator and radiator, O2 sensor, 2 screws on timing cover, screws to vc....then it finally came off.
dorichimpsak
