dorichimpsak
So my fan would not come on when car was in normal op temp. I disconnected the plug to the bottom of the radiator and found that only the condensor fan comes on. I was checking the fan relay and everything seemed fine so I started to push on it and move it back and forth. The fan comes on when I firmly press the relay to either side...it's like a contact is missing somewhere. So I pulled the fuse box off and found this plug to have a missing female end on the bottom row second column from the left. Is that suppose to be missing and is that the actual plug and wires that go to the relay? Thanks for any help.
http://tinypic.com/r/35alkdh/6
