Sunroof acting weird...
Postby toayoztan » Thu Feb 07, 2013 1:36 am
So when I stripped the car down, I took out the sunroof. I cleaned up all the rails, components, etc. Freshened it up and put it back in. I tried "centering" the sunroof motor gear according to the manual. Put it in. Installed the sunroof.
I hook up the wiring on my car as a temp set up to test it out.
It works...kind of. Whenever I hit the tilt or slide button, sometimes it operates smoothly, but more often it just cuts in and out, with the tilt doing majority of the work and the slide button hardly working.
At first I thought it was weak power to the motor, so I tried setting up my wiring better from the battery...but everything else on my car works perfectly good - rear windshield motor, lights, door windows even (which can suck a bunch of power). So I am pretty sure I am getting enough power to my sunroof motor.
Any of you have had the same issue, whether you took out your sunroof or not? It doesn't seem like the sunroof is getting stuck at all, that's not the issue. I'm just trying to decide if the controls are messed up, perhaps need cleaning (or swapping - i have a spare I'll swap in tomorrow, but wanted ideas from the forum too)...or if the motor is messed up, which I'll have to try and swap out from a salvage. When I tested the motor directly from the battery when it was out of the car, it worked fine...hopefully I didn't f*** it up by doing that.
Just curious if you guys had any ideas or experienced anything similar?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Re: Sunroof acting weird...
Postby RedCelicaTRD » Thu Feb 07, 2013 3:36 am
Did you put a thick coat of grease on it?
Postby toayoztan » Thu Feb 07, 2013 4:00 am
RedCelicaTRD wrote:Did you put a thick coat of grease on it?
I believe so, the best I could. I wore a glove, globbed grease on the palm, and ran it up and down each cable. Mistake?
It operates smoothly when it wants to go. When it just suddenly stops randomly, like when I slide it back. I continue to hold the button down or repush the button, while pushing on the panel to go back, and nothing happens (as if the motor either just died or contacts on the switch or something is effed).
I can always pull the whole assembly again, but I would rather not. It's a pain as it is that I have to remove the head board/ceiling panel to get to the motor, if I need to replace it.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby phattyduck » Thu Feb 07, 2013 5:19 pm
Is the motor grounded to the chassis somehow? Not sure how the wiring is done, but make sure a ground point wasn't painted over or something...
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby toayoztan » Thu Feb 07, 2013 10:37 pm
phattyduck wrote:Is the motor grounded to the chassis somehow? Not sure how the wiring is done, but make sure a ground point wasn't painted over or something...
Nothing painted or touched in that area.
I swapped out the controls with a spare one I had, same thing. I took out the motor (I saw in the BGB you can remove the motor without completely removing the headliner).
I'm going by the junkyard tomorrow to pick up a spare one...2 or 3 of the celicas there have sunroofs, just hoping they are the 92-93 (because I think the plugs are different). I'll probably pick up the spare relay boxes and controls too. I know the sunroof assy itself isn't binding and is lubed well, so that's not the issue.
I think I probably messed up the motor when I tried calibrating it according to the BGB.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby Killtodie » Thu Feb 14, 2013 9:22 pm
I have a similar issue with mine. My tilt controls do not work, open fine, but wont close until I hit the tilt button and then close button only works for 1 second at a time, so I have to keep pressing it.
Switch is fine. Could not find fault.
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Postby toayoztan » Thu Feb 14, 2013 10:27 pm
Killtodie wrote:I have a similar issue with mine. My tilt controls do not work, open fine, but wont close until I hit the tilt button and then close button only works for 1 second at a time, so I have to keep pressing it.
I figured out it's the sunroof motor itself that needs to be calibrated/reset to the correct position, WITH the sunroof itself in the closed position (from tilt to close or from open to close).
I can take a few pictures to show you what I mean. The BGB is horrible at explaining what needs to be done.
Mine had the same problem...I'd push a button, and it would cut out and only work for a second or two at a time. Or I would hit the tilt close button, and it would close, but then continue to open and slide back and didn't stop at close like it should, etc. It was acting funky.
But it works now!
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby Killtodie » Fri Feb 15, 2013 9:30 pm
If you can post pics that would be awesome. I would love to get my problem solved. its kinda annoying.
Killtodie
Postby Twincam.22 » Mon Apr 13, 2015 12:53 pm
Major thread revival here but does anyone have the part of the manual that covers resetting of the sunroof controls/switches?
I;m having very similar problem.
Twincam.22
Postby Twincam.22 » Mon Apr 13, 2015 1:08 pm
found the manual on here but does not tell you how to set up the limit switches is there something im missing?
http://bgbonline.celicatech.com/93celica/
Twincam.22
