Alright, last summer I went with a cometic ''Street pro'' top end gasket kit, everything worked great. But, I recently I noticed some humidity surrounding the valve cover (slight oil leak), now my guess would be that the cometic gasket isn't as good as the oem one, either way, I will be ordering an OEM one this spring, but my question remains, I looked for the correct procedure in the bgb, I was stunned when I saw the torque on these bolts, 6N/M, thats insanely low and at that torque, the cam cover seems lifted by the gasket... Oh, and I got myself some hex bolt to make sure I don't re-use the awful phillips screw (toyota... what?why?)...
Anyway, anybody has some cue on how to properly install/torque the valve cover?
