Looking for Turbo oil gasket
Killtodie
New member
I've been unable to find this part number anywhere.
Its the gasket that goes between the flex line coming off the coil cooler, and going to the oil feed/return line to the turbo.
Its not a kit, its a single gasket. Not the 3 turbo oil/cooler gaskets, its the one that is between the large oil pipe, and the flex pipe going to the cooler on the block.
Thanks
Well-known member
I can't quite envision where the gasket you're referring to lives. Is it one of these four?
Well-known member
Yep 15526-88380 is the number I get for it. I'm not sure what the whole 2 different numbers thing is from Toyota.
Killtodie
New member
Well shit, no one has this part anymore.
Ordered from Amazon, got a refund saying part is unavailable.
Ordered from another online Toyota dealer, same thing, got issued a refund today.
Ugh
Moderator
You can but sheets of gasket material at places like autozone. It's made by felpro and usual comes in 5"x5" squares or larger rolls. It will work fine for that gasket, which if I remember right is a paper gasket to begin with. Trace the old gasket or fitting and cut it out.
Killtodie
New member
I tried making one, not happy with the results. Kinda rough, not easy to make, and it sprung a leak.
surface needs more prep. And I'll be much happier with an OEM gasket.
Going to keep trying different places.
___Scott___
Active member
Another trick, kinda kludgey, is to use high temp RTV silicone. Spread a thin uniform film (about the thickness of a credit card) on one of the mating surfaces and let it cure for 24 hours. Then assemble the pieces. As long as you don´t over tighten anything it should work.
Make sure your surfaces are clean and don´t get any silicone in the drain hole.
Killtodie
New member
tried that originally, didnt hold.
I need to smooth down the mating surface, might not be straight
Well-known member
If you've got friends at a parts store maybe bring it in and see if they can match it up to a gasket from something else.
New member
Ive only made $500+ orders from them before so it hasn't been so much of a problem.
Not sure what it'll be like for a small package.
Let us know what they quote you.
Top
