Sorry in advance for the long post,
I did a few searches and came up empty handed. I tried adjusting my timing by myself and it's at 12-13 BTDC at idle. A hair one way and it's at 15 and a hair the opposite and it's at 5-6. I decided to leave it at 12 and test it. What's happening is the car sounds like a subaru for the first few mins idling and smooths out. But then the first 10 minutes of driving are rough like a subaru, is slow to rev, slow to boost, and is very weak. It doesn't smooth out until I hit a long stretch and keep the rpms steady for a few mins, at which point the everything goes normal and the car runs PERFECT! What's strange is the turbo is very audible all of a sudden, like it just woke up. Park the car, kill the engine, let it sit for 30 mins, the temp drops completely. Start car and it sounds like a subaru--have to drive 10 mins again before it's normal.
Timing is the same at 12-13, no overheating, so i don't think it's the problem.
I can't find any vac leaks.
Burped coolant
I do have CEL 71 (EGR) Euro spec car on USDM ECU (ordered 10k and 2k resistors).
ATS Built 2.0 SB and head with shimless conversion and GSC 268 cams/adj gears
stock injectors
3" turbo back
New dizzy, cap, rotors, coil, igniter, plugs and plug wires, new walbro pump, new fuel filter
Only thing I can think of is I'm coming up on 100 miles since the build and need to retorque.
Any ideas what could cause this behavior?
Burped coolant
stock injectors
3" turbo back
