("wanting" is a loose term here)...The fuel lines and rear brake lines are looking a bit crappy...I have searched and haven't found much on doing this. First plan was to buy all the factory lines, but new plan is (maybe) to run aluminum fuel lines and steel brake lines.
Few questions:
What size line should I run? Fuel I was planning on 3/8" o.d. (fairly stock hp maybe a bit more eventually probably no more than 300)...and brake- I wanted to keep the same as stock 1/4"?
Next, fittings...any idea what size fittings I will need to bolt up to factory parts with new universal lines?
Does it make sense to keep stock fuel filter at this point or replace with aftermarket inline any pros/cons...?
I am planning on going thru making a list and checking it twice later...I will keep posted if I don't hear anything here! Thanks!
Few questions:
