Mr Alltrac":l1nzch5u said:
When I had a leak in my intake manifold gasket it seemed similar to this. It would max out my arm uego wideband at idle but would run normal when I was cruising or under boost.
Mine is fine at idle...only when light throttle cruising with 0psi to vacuum
klue":l1nzch5u said:
scott in order to better understand your situation we need some more details.
how are you measuring the AFR?
how are you controlling fueling?
also give some details on your set up
Megasquirt is a great option on a budget. As a dealer for Megasquirt let me know as much as you can and can recommend the best set up for you
Luke
AFR is being measured on an AEM uego wideband, the wideband is also doing the narrowband output to the ECU since my stock 02 sensor took a dump and i didn't want to fork out the money for it when my wideband can do the same thing.
fueling is stock as far as FPR and injectors. I do have a walbro 255LPH in the tank.
Currently running 12PSI boost and everything else is set up the same as a ST205 should be.
I pulled the EFI fuse and let it sit for a while then went on a drive and didn't notice the issue again. I have noticed it running INCREDIBLY rich lately more than it normally does and was looking into getting a megasquirt mostly just for tuning out some of the fuel...not looking to make big power....yet...
anyway luke I am looking into the DIYPNP from DIY Autotune for my MS. I could probably get the one they have for the ST185 but I am intriuged by building my own and saving around $300 bucks doing it lol! Let me know what sort of suggestions you have? I know in the past there was an issue with the cam gear in the distributer being an issue but according to the folks over at DIY Autotune it isn't so much of an issue with MS2 correct? any info you can give me would be great! Also what are your thoughts about MS3? is it worth it to go with MS3 vs MS2 if i'm just tuning out some fuel and controlling boost? I can always upgrade it down the road if I desire right?
