Noise from the trans/diff
Postby Killtodie » Wed Jan 07, 2015 7:54 pm
My front diff has been making some noise recently. ST165, 3rd day now. It just got really cold, low single digits. And from the first day when it was -2 in the morning my diff, and/or trans started making whining noise, kinda like a bad bearing.
I only drive 4 miles to and from work, about 15 minutes. I dont know if the trans had enough time to reach operating temp.
I have isolated this noise to either the differential, or the trans output shaft. It occurs with the engine off, and the clutch depressed.
The rear wheels are still getting power, I can spin them, and I can see the drive shaft spin under load, so I dont think anything is broken. (No handbrake, so I can see the shaft out of the mount hole)
Could it be a bad bearing on the output shaft? That's always spinning right?
What if I put the car in FWD mode, does that physically uncouple the diff?
What can I do to narrow down the noise?
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Re: Noise from the trans/diff
Postby FC Zach » Wed Jan 07, 2015 9:39 pm
I have the same thing going on with my car. Only happens when the temperature is ~30° and below. I have also isolated the sound as well, I thought a bearing. . Really not sure either.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby ___Scott___ » Wed Jan 07, 2015 10:43 pm
Both of my ST165s have whined when cold. It goes away as the trans warms up.
I did notice that after I ¨topped off¨ the trans fluid level with the remains of a bottle of Mobil1 75W-90 synthetic gear lube that I run in my rear diff, the cold weather whining has nearly gone away. The shifting got a little smoother too, much to my surprise. I expected the opposite.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby FC Zach » Thu Jan 08, 2015 5:05 am
I should have noted what oil I'm using and that I also have a synthetic oil. After my clutch change recently, I filled the transmission with AmsOil Severe Gear 75w-90. It still whined yesterday morning leaving work.
Tonight, before leaving for work I warmed the car before the drive since it is only 9°F here and there was no whine at all during my drive.
Weird stuff, only happens when the tranny is cold.
FC Zach
Images: 9
Postby Killtodie » Thu Jan 08, 2015 1:43 pm
I figure it would happen when its cold. Today is even colder, -7F.
I have been planning on topping it off since I did my clutch two years ago, so that's on the to do list.
anyone know the technical reason why it whines?
Update:
Drove to work, it was slightly louder than before. Half way to work it seemed to have stopped almost entirely. Now I'm worried that something blew.
I'll see if I still have AWD capabilities on the drive back.
Update:
verified that diff still works, still noisy, but not as much
Another Update:
I dont know if its coincidence, but the noise went away.
Two things happened: It got warm, mid teens, 20's, and I finally bought new winter tires. The pair I had before had uneven wear due to bad alignment, so I was straining my drive line, but hopefully no damage was done.
We'll see how it sounds when it gets cold again.
Final update:
This week there was a day when it was really cold in the morning, low single digits, and high teens in the end. The diff made noise on my way to work, and was quiet on the way back when it was warmer, so it appears to be temp related.
Would anyone know the technical reason for this?
Killtodie
Postby Killtodie » Thu Feb 19, 2015 4:56 pm
-5F today, and jebus my diff was loud.
Is this causing damage?
Killtodie
Postby ___Scott___ » Thu Feb 19, 2015 7:31 pm
I just drive slow until the noise eases up. When it's really cold, I sometimes take a slow lap around the parking lot before I hit the streets.
I've driven an ST165 as my daily driver since 1996, and through Colorado winters, and never noticed any damage.
Scott
SONY
___Scott___
Postby warracer » Thu Feb 19, 2015 7:50 pm
___Scott___ wrote:I just drive slow until the noise eases up. When it's really cold, I sometimes take a slow lap around the parking lot before I hit the streets.
^ This
My 185 has been doing it since I owned it, its been 3 winter now at around -30 and it'll whine in the front for 5-10min max, I just don't drive the car hard when its cold (and you shouldn't). Never experienced a break down due to that :shrug:
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby Killtodie » Thu Feb 19, 2015 9:45 pm
I drive 15 to work in city traffic, so the fastest I go is 30. Noise goes away just as I'm nearing my destination.
Would be nice to know what's causing it exactly.
Killtodie
Postby Rallly » Wed Dec 02, 2015 6:31 pm
Any updates on what we can do to solve this?
Rallly
Postby Killtodie » Sat Dec 05, 2015 3:38 am
Rallly wrote:Any updates on what we can do to solve this?
From what I heard if you use the correct oil, and its topped off, this is a normal thing and is a non issue.
I remember googling this more, and talking to other all trac guys at meets. some have it, some dont.
Killtodie
Postby FC Zach » Sat Dec 05, 2015 7:22 am
Let it warm up prior to driving.
Killtodie wrote:From what I heard if you use the correct oil, and its topped off, this is a normal thing and is a non issue.
That's basically what I've gathered.
FC Zach
Images: 9
Postby Rallly » Sat Dec 05, 2015 2:28 pm
I don't see how such a loud whine is normal.. What are the alltrac owners with out noise putting in their diff and trannies?
Rallly
Postby Killtodie » Fri Dec 11, 2015 3:43 pm
You cant warm up a manual trans before driving. Driving is what warms it up, and takes about 10 minutes.
That's basically what I've gathered.[/quote]
I would love to get an actual explanation on the cause of this. My friend had an ST162 and had no noise, so I assume its the transfer case/diff
Killtodie
Postby FC Zach » Fri Dec 11, 2015 4:05 pm
Killtodie wrote:You cant warm up a manual trans before driving. Driving is what warms it up, and takes about 10 minutes.
Correct but heat does transfer from an engine through an aluminum transmission and as I've said in a previous comment. . doing so prevented the noise in 9 degree weather, for me at least. Results may vary :)
FC Zach
Images: 9
