Noise from the trans/diff
Re: Noise from the trans/diff
Postby Killtodie » Sat Dec 12, 2015 5:43 am
FC Zach wrote:
Killtodie wrote:You cant warm up a manual trans before driving. Driving is what warms it up, and takes about 10 minutes.
Correct but heat does transfer from an engine through an aluminum transmission and as I've said in a previous comment. . doing so prevented the noise in 9 degree weather, for me at least. Results may vary :)
Its not the heat transfer, its the fluid coupling that occurs between your input and output shaft that warms things up.
The engine blocks is luke warm to the touch at best at idle.
I had my car idle for over 10 minutes in negative/single digits, still made noise until 10 minutes of driving. But that's me.
1988 Chrysler Conquest
As seen on YouTube https://www.youtube.com/watch?v=YIY4wuwc8XA
1988 Toyota Celica All-Trac
Killtodie
Users browsing this forum: Yahoo [Bot] and 1 guest
