head gasket problem?
Postby peteleetzor » Thu Feb 12, 2015 9:51 pm
recently the temperature has been going over the mid line randomly and fan will turn on. when I stopped the car and shut of, it would bubble a little and smoke from the overfill. it went away like after 2-3 times. I filled the radiator after.
fast forward 2 months *didn't drive*
now the temperature goes a little more then midline, fan turns on frequently and when I stop water vapor will steam from the overfill.
on the freeway just now, temperature went 3/4 way goes back to mid and just jumps around.
what should I do? I had new thermastat, water pump, new seals all put in like 4 months ago at the dealer.
peteleetzor
Re: head gasket problem?
Postby yyonline » Sat Feb 14, 2015 8:13 am
Are you sure it's water vapor steaming from the overflow tank? Bubbles could also be trapped air in the cooling system or combustion gasses.
If it bubbles almost immediately after starting the car, you're looking at a blown head gasket or cracked block or head. The combustion gases under pressure are leaking out of the combustion chamber and into the coolant passages. Only way for that to happen is if there's a path from the combustion chamber to the coolant - which has to be a bad head gasket, or a crack. You can buy test kits to check if your coolant has been contaminated by combustion gases. Had this happen to my neighbor's Camry 5S-FE. Got ready to replace the head gasket, tore everything down only to find a cracked block.
Did the dealer use a genuine Toyota thermostat? Thermostats are one of the things I insist on buying genuine parts as I've read of a lot of issues with aftermarket thermostats. Obviously your fans are working. I'm assuming no external coolant leaks. How well did the dealer bleed air from the coolant? Trapped air will result in bubbles in the overflow as well, but you should notice the fluid level in the overflow decreasing over time as it expels air and sucks in fluid from the overflow. A bad radiator cap can also introduce air into the system. Be careful with replacement radiator caps - most genuine Toyota/Denso radiators use a shallow radiator cap, and some aftermarket replacement radiators use a deep radiator cap. I've seen dealer techs throw a genuine Toyota shallow depth radiator cap on an aftermarket radiator designed for a deep cap resulting in all sorts of weirdness.
yyonline
Postby celica_gtx » Sat Feb 14, 2015 4:25 pm
your story sounds similar to mine...
mine ended up being HG.
viewtopic.php?f=21&t=49092
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby toddy2 » Mon Mar 02, 2015 3:39 pm
Same happened to me. Started to heat. Up and down in temperature. Water came out of overfill tank. Changed radiator and thermostat. No help by changing parts. Result: blown HG.
toddy2
Postby Il_Barone » Wed Mar 04, 2015 1:01 pm
I have the same problem.
After filling the radiator, when i use the car for about 1 or 2 hours, it bubble and smoke vapor from the overfill tank, and the temperature rises.
I've noticed a leak under the engine, under the oil turbo hose, but i can't understand where it starts leaking.
Are there tests, after eliminating the water leak, to do to exclude any problem with the head gasket?
Thanks!
Il_Barone
Postby underscore » Wed Mar 04, 2015 3:38 pm
Hydrocarbon tests can be done to check for combustion gases in the coolant system.
Postby celica_gtx » Wed Mar 04, 2015 5:10 pm
underscore wrote:Hydrocarbon tests can be done to check for combustion gases in the coolant system.
doesnt always work...
i did that multiple times and had neg results every time with a blown HG.
would only get hydrocarbons under load conditions such as boosting. and my gaskets was blown in 2 spots.
celica_gtx
Postby r-town » Wed Mar 04, 2015 8:47 pm
r-town
Postby milehigh_alltrac » Wed Mar 04, 2015 10:41 pm
A good way to test this is to do a compression test with the rad cap off. If the head gasket is blown between the combustion chamber and cooling jacket, it will push coolant out of the radiator fill.
milehigh_alltrac
Postby peteleetzor » Fri Mar 13, 2015 8:44 pm
I think is going to blow anytime soon. luckily spring break is next week.
I really want to wrench on the car, and throw my ct20b on as well. my question is
what part should I use for the head gasket? and should I rebuild my head once I take it out? also any tips and things to look out for?
car is 93 alltrac
peteleetzor
Postby celica_gtx » Sat Mar 14, 2015 1:59 pm
Fallow TM. Measure your head or take it to a machine shop. Most will measure it for free. And do what they recommend. I would definitely buy a top end kit and replace seals and gaskets while your in there
celica_gtx
Postby Il_Barone » Mon Jun 29, 2015 8:41 pm
Well, i found the problem... i have a crack in the engine block :bangshead: :bangshead: :bangshead:
It's just above the water pump.
I have to find another block, and it will not be an economic job (a good block,gaskets kit, rings, bearings ecc)
I can't understand one thing: how an engine block can crack in this way??? How???
My car it's all original, no tuning, no races, ordinary maintenance always performed...... :cry: :cry: :cry:
In these days i'll post some pics.
I'm going to sleep with tears in my eyes...goodnight
Daniele.
Il_Barone
Postby Awesome-Trac » Mon Jun 29, 2015 10:20 pm
Il_Barone wrote:Well, i found the problem... i have a crack in the engine block :bangshead: :bangshead: :bangshead:
Daniele.
Think of it this way, if you weren't the first owner to purchase the car then the damage could have been done by previous owners before you. There's a chance the the motor could have gotten extremely hot due to lack of cooling and fail
•Daniel
Awesome-Trac
Postby alltracman78 » Wed Jul 01, 2015 9:50 pm
Daniele.
This is a documented problem with our engines. The casting is too weak [thin] at that corner.
Postby peteleetzor » Thu Jul 02, 2015 2:18 am
yikes that sucks to find a cracked block.
Well I flushed the radiator, all normal color, took a look at my OEM 20+ year old cap and literally is a metal cap with nothing else in there. :oops: Got a replacement cap and the car temp is nice and stable.
sad thing is my turbo seals is going....all that spool and no power....so greatttt, summer here I come.
peteleetzor
