How hard is it to remove the center diff on a ST165
Postby madspeed » Sun Mar 15, 2015 1:35 am
How hard is it to remove the center diff on a St165 to get it welded ? Does the whole tranny need to be dropped ?
madspeed
Re: How hard is it to remove the center diff on a ST165
Postby athousandleaves » Sun Mar 15, 2015 3:47 am
You'll be dropping the motor & transmission, splitting them taking the transfer case apart and then you can get at it.
What makes you think it needs servicing?
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby madspeed » Sun Mar 15, 2015 3:49 am
was hoping to get it welded/locked up for ice racing. looks like that is a dead end as I really don't wanna pull the motor out.
madspeed
Postby athousandleaves » Sun Mar 15, 2015 2:12 pm
The viscous center is pretty immediate in terms of engagement. If you read up more on how the 4WD system is setup you'll see that the car is a true 50:50 split, not FWD till slip.
Get all four wheels in the air on some stands and then drop it into first and you'll see.
1992 White turbo4WD
athousandleaves
Postby madspeed » Sun Mar 15, 2015 2:44 pm
That's grewt to hear. The car currently has a welded rear diff that causes massive understeer. I'm hoping to find a Torsen or clutch type rear diff to replace it.
madspeed
Postby Redrkt01 » Wed Mar 18, 2015 2:57 pm
madspeed wrote:That's grewt to hear. The car currently has a welded rear diff that causes massive understeer. I'm hoping to find a Torsen or clutch type rear diff to replace it.
Look at the ST205 rear torsen....
1989 ST162
1988 ST165 Black
1988 ST165 Red Parts Car
Redrkt01
