steering rack leaking, boots torn
Postby Smaay » Tue Mar 24, 2015 4:19 am
what are my options? is it rebuildable? just replace? and the worse part, engine needs to come out to change.
2001 Celica GT-S 2ZZ-GTE
90 Celica All-Trac 3S-GTE
97 Supra 2JZ-GTE
97 Celica GT 3MZ/1MZ hybrid
Smaay
Re: steering rack leaking, boots torn
Postby zaluss » Tue Mar 24, 2015 2:12 pm
Smaay wrote:what are my options? is it rebuildable? just replace? and the worse part, engine needs to come out to change.
Easier just to buy a re-manufactured rack. You don't have to pull the engine to replace but it certainly makes it a lot easier. Good opportunity to do some refresh on stuff too. Otherwise you have to start pulling crossmembers off, tipping the engine over slightly while pulling it slightly, and slide the rack out.
zaluss
Postby Smaay » Tue Mar 24, 2015 5:21 pm
so drop the k frame, then the center cross beam. let the engine rock and you can slide the steering rack out?
anyone recommend the best one to get... also is the regular 5th gen celica the same rack?
97 Supra 2JZ-GTE
Smaay
Postby yyonline » Sun Mar 29, 2015 4:35 am
For 90-93 the GT, GT-S, and All-trac steering racks are the same.
You can buy a remanufactured rack through the Toyota dealer. I've heard they're decent. Toyota gets is remanufactured steering racks from Maval. You can buy the Maval rack for less than the dealer reman. It's available from Worldpac. Search for W0133-1745725 and you'll find some online resellers. I put a Maval rack in my friend's Sienna, and it's held up well for the last 2 years.
yyonline
