speedometer inaccurate after swap st165 to st205
Postby black88alltrac » Wed Mar 25, 2015 1:24 am
i put the st165 manual speedometer setup in the st205 tranny. i did happen to change out the gear that goes in the transmission and swapped it to the st205 gear thinking that it may have a different number of teeth. now when i drive the speedometer reads 10-20mph higher than normal. when i'm doing 80mph it says i'm doing 100 on the speedometer. My wheel and tire size are close to oem diameter so i dont think it is that.
did anyone else do a st205 swap into a st165? is your speedo accurate?
black88alltrac
Re: speedometer inaccurate after swap st165 to st205
Postby scottjackson1209 » Thu Mar 26, 2015 4:15 am
Mine is perfectly accurate above 10mph. It doesn't register anything below 10
scottjackson1209
Postby black88alltrac » Thu Mar 26, 2015 6:35 am
thanks for the reply, i think i just need to replace the part that controls the needle, the odometer reads correctly, i just went 50 miles on gps and it was 50 miles on the odometer even though i was going 70mph on gps but the gauge read 90mph.
black88alltrac
Postby scottjackson1209 » Thu Mar 26, 2015 6:39 am
That makes no sense, they are driven by the same mechanism I believe...
scottjackson1209
Postby black88alltrac » Thu Mar 26, 2015 3:56 pm
no, the speedo needle is magnetically driven and the odometer is gear driven.
black88alltrac
