Gen3 3SGTE V Belts
Gen3 3SGTE V Belts
Postby zaluss » Tue Apr 07, 2015 4:25 am
I can't seem to find anyone who carries the accessory belts for the gen3 3SGTE. The part numbers I found don't show up on Lithia and I think they are the only dealership to carry gen3 parts. KO racing, ATS, and PrimeMR2 don't seem to carry them either.
Any ideas?
EDIT: Actually based on this http://www.fensport.co.uk/Parts/Model_19/Category_8/, these should work.
http://www.amazon.com/Bando-5PK1125-Qua ... B002EC2JZ6
http://www.amazon.com/Bando-5PK760-Qual ... B002EC5BDI
Can anyone confirm this?
zaluss
Re: Gen3 3SGTE V Belts
Postby yyonline » Tue Apr 07, 2015 7:35 am
I cross referenced with a different source and came up with the same.
If you wanted to stick with Toyota parts...
5PK1125 I can't find from Toyota USA, but 99365-91120 is 5PK1120 and is plenty close enough to work.
3PK760 is available from Toyota USA 99363-90760-83
yyonline
Postby yyonline » Tue Apr 07, 2015 7:39 am
Well...I came up with almost the same thing. For the power steering belt, I'm 95% sure you want 3PK760. You have 5PK760 in your original post. I didn't notice that until after I posted.
yyonline
Postby zaluss » Tue Apr 07, 2015 10:55 am
Thanks man. I went ahead and ordered the 3PK760 and 5PK760. We'll see how that goes.
zaluss
Postby Smaay » Tue Apr 14, 2015 1:45 pm
what was the results from this?
2001 Celica GT-S 2ZZ-GTE
90 Celica All-Trac 3S-GTE
97 Supra 2JZ-GTE
97 Celica GT 3MZ/1MZ hybrid
Smaay
Postby zaluss » Tue Apr 14, 2015 2:33 pm
Smaay wrote:what was the results from this?
I got the belts in but I haven't had a chance to compare them. I'll find out Thursday when the timing belt tensioner gets here from PrimeMR2 and I'll update then.
zaluss
Postby zaluss » Fri May 01, 2015 1:43 am
Sorry for the late update. Power steering belt worked great but the alternator/ac belt was incorrect.
http://i.imgur.com/2y7Aczw.jpg
http://i.imgur.com/6SOj2xE.jpg
http://i.imgur.com/DBuModX.jpg
zaluss
Postby yyonline » Fri May 01, 2015 2:09 am
You need 5PK1125 as you linked to in your original post:
zaluss wrote:http://www.amazon.com/Bando-5PK1125-Qua ... B002EC2JZ6
That one is out of stock though. It may be an uncommon size.
5PK1120 or Toyota part number 99365-91120 should be close enough to work (only 5mm difference in total belt length)
Rockauto has 5PK1123 from Gates (good brand):
http://www.rockauto.com/catalog/moreinf ... d=6&jpid=0
yyonline
Postby zaluss » Fri May 01, 2015 2:23 am
yyonline wrote:You need 5PK1125 as you linked to in your original post:
Ha. Rockauto seems to only have it in the UK. $40 to ship it to the US.
I went ahead and bought a Bando brand 5PK1125 from ebay from a seller in Maryland. I'll report back on that.
zaluss
Users browsing this forum: Baidu [Spider] and 3 guests
