st184 tranny Blown
st184 tranny Blown
Postby ViciousDelta » Thu May 14, 2015 4:46 pm
I ran over a dead deer on the highway last night in my 91 GT and knocked a pinhole in the transmission. I do longer have 5th or reverse gear. Tried flushing and refilling the tranny but to no avail. My local wreckers has a 92 Camry with a 5sfe and a manual tranny. Will the camrys transmission work? The wreckers says no but i was pretty sure that all S series engines used the same transmissions regardless of what vehicle they were in. Also my 91 has a 98 RAV4 3sfe in it. But seeing as it has a 5sfe tranny hooked to it now there should be no problem. Anyone know for sure? I dont wanna drop 150 bucks on it and it not actually work.
1988 AllTrac, 1st Gen 3S-GTE
1991 Celica GT Liftback JDM 3S-FE
1979 SR5 Corolla Liftback, 2-TC
1968 Mustang GT Coupe w/ 351 Cobra Jet
ViciousDelta
Re: st184 tranny Blown
Postby fussellbug » Thu May 14, 2015 7:48 pm
The 92 Camry runs the S51 transmission. The bellhousing, clutch and mounts and shifter should all be the same as the S53 in your Celica. The only difference you may notice is the gear ratios being slightly different which may change the speeds (MPH) at which you change gears.
fussellbug
Images: 36
Postby ViciousDelta » Sat May 16, 2015 9:01 am
i imagine the gears are slightly longer? which is fine as my 184 drives 120 miles a day when i work so im down for all the mpg i can get lol
ViciousDelta
Postby fussellbug » Sat May 16, 2015 11:15 am
I know for certain that 5th gear is taller and will give you lower engine RPM at highway speeds, not sure about the rest.
fussellbug
Images: 36
Postby ViciousDelta » Sun Jul 05, 2015 6:32 pm
Been running it for about 2 months now with the Camry 5 speed. The 5th gear is almost like an overdrive, I love it. 95mph at 3100rpm. I have no doubt that if there was no speed limiter the car would easily do 140-150mph. The gas mileage is even better. Who would a though hitting a deer would save me so much money. I'm getting close to 40mpg now and I can do multiple trips to and from work on a tank now instead of 3 trips. Definitely a huge drive ability mod!
ViciousDelta
