Need help
Need help
Postby Glitter&Doom » Thu May 21, 2015 4:04 am
Putting back my ST165 and I need help with some sensor plugs. Two of my plugs got pulled out the wires and I need help identifying wich wire goes into what pin.
First plug goes on the intake manifold. Has 2 wires. I need to know which wire goes on the left pin and which goes on the right.
Glitter&Doom
Re: Need help
Postby Glitter&Doom » Thu May 21, 2015 4:06 am
Second wire comes off the harness that's close to battery location.
I believe it's a yellow wire with a green stripe. Single wire. I don't know what or where it plugs into. Any help is greatly appreciated.
Glitter&Doom
Re: Need help
Postby Mr Alltrac » Thu May 21, 2015 2:36 pm
http://bgbonline.celicatech.com/88alltr ... ac_bgb.php
You can give that a try and see if you can find it in the wiring section or egr section.
Mine was pulled already when I bought the car so I can check mine. Hth!
Mr Alltrac
