Broken plastic side
Broken plastic side
Postby Killtodie » Fri May 29, 2015 12:59 pm
The plastic on the doors of my ST165 have come off. All the anchors are rusted, and most have broken clean off the plastic side.
What is the solution to getting it back in place? Has anyone come up with anything decent?
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Re: Broken plastic side
Postby Anoo21 » Fri May 29, 2015 2:46 pm
Are you talking about the side flares? I was going to get similar clips and use double sided tape. Going to hopefully paint the car soon and I'm going to have to think of something.
Anoo21
Postby Killtodie » Fri May 29, 2015 6:38 pm
Yes. What clips will you be using? I was thinking of having some machined out of aluminium on a cnc machine, and jb weld.
Killtodie
Postby Anoo21 » Sat May 30, 2015 2:45 am
I work at a Toyota dealership and was going to check with the body shop if not I was just going to try different odds and ends.
Anoo21
