Timing belt
Timing belt
Postby 819_ay » Mon Jun 01, 2015 11:36 pm
Just wondering if someone had tried these before? http://m.ebay.com/itm/190773771851
Just not sure if it's good or not... Cheap but good?
819_ay
Re: Timing belt
Postby Awesome-Trac » Tue Jun 02, 2015 12:56 am
819_ay wrote:Just wondering if someone had tried these before? http://m.ebay.com/itm/190773771851
Cheap and good never mix
•Daniel
Awesome-Trac
Re: Timing belt
Postby 819_ay » Tue Jun 02, 2015 1:01 am
That's the rule of thumb... But you never know... I was Taking a chance that's all
819_ay
Re: Timing belt
Postby underscore » Tue Jun 02, 2015 3:11 am
If our timing belt was easier to access I might risk it, but given how heap brand name parts are if you use the right sources I wouldn't risk it.
Re: Timing belt
Postby yyonline » Tue Jun 02, 2015 5:11 am
The kit pictures a Mitsuboshi timing belt, which is good. But the listing doesn't specify brands, so there's no telling what brands the other stuff is or if you'll get the belt that is pictured.
Here are some good part recommendations to save money on timing belt components for the 2nd gen 3SGTE.
Water pump: Aisin WPT-056. Available at RockAuto, Amazon, etc.
Timing belt idler pulley is Koyo PU355816RR9D which is Worldpac P/N W0133-1631471: http://www.amazon.com/Koyo-Timing-Belt- ... k-c1514-20
Tensioner pulley is Koyo U00392B. Available at Amazon.
Mitsuboshi timing belt: http://www.amazon.com/Mitsuboshi-W0133- ... k-c1514-20
These are the same brands you'll get if you order the part through the dealer.
I haven't found a good aftermarket tensioner, so I'd recommend the dealer part for that. There are plenty of reliable seal manufacturers, but the Toyota ones aren't that expensive so I'd just go that route. I hope these parts save you some money while still getting good quality stuff.
yyonline
Re: Timing belt
Postby underscore » Tue Jun 02, 2015 7:04 am
Both pulleys can also apparently use Gates P/N: T42025, which should be available from RockAuto, alternatively I believe KO Racing has all these parts available.
Re: Timing belt
Postby 819_ay » Tue Jun 02, 2015 3:32 pm
Cool thanks a lot guys... Checking out ko racing and prices aren't too bad
819_ay
