Head
Head
Postby 819_ay » Tue Jun 09, 2015 8:28 pm
I have a question... Is it possible to remove the head without removing the throttle body? And is there a way to check the head gasket? Without removing the head with the engine out of the car.. The engine is a Gen 2 3sgte thanks
819_ay
Re: Head
Postby zaluss » Wed Jun 10, 2015 1:47 am
The throttle body is connected to the intake manifold and the intake manifold is connected to the head. So yes while it is possible to keep both intact while removing the head, it will add a lot of weight and complexity to the removal. It can be done.
A blown headgasket will provide certain symptoms such as bubbles in the coolant, coolant smell from the exhaust, oil mixing in the coolant causing that "milkshake" appearance, and your engine overheating.
zaluss
Re: Head
Postby underscore » Wed Jun 10, 2015 2:39 am
You can also do leakdown and carbon tests to see if it's failing.
Re: Head
Postby toayoztan » Wed Jun 10, 2015 3:01 am
If you check cylinder compression, a clue to a blown headgasket may demonstrate two adjacent cylinders with low compressions.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Re: Head
Postby yyonline » Wed Jun 10, 2015 5:08 am
I don't know that it is possible... I changed the valve cover gasket on mine a month or two ago. With the throttle body on, I couldn't lift the valve cover up high enough to clear the camshaft bearing caps. And you'll need to get the cover off and camshafts out in order to get access to the head bolts. It may be possible to clear the bearing caps, but it wasn't worth the time and was easier to just remove the throttle body.
But why would you even want to do this? The throttle body is held on with 4 bolts and takes all of 2 minutes to remove. So I'm not sure you'd gain anything by leaving it attached.
yyonline
Re: Head
Postby 819_ay » Wed Jun 10, 2015 10:35 am
Sorry I meant the intake Manifold not the throttle body my mistake...and the engine out of the car, so checking coolant is out of the question, would have to do a compression check to see but again the engine is not in the car...
819_ay
Re: Head
Postby underscore » Wed Jun 10, 2015 8:23 pm
If you've got it out already IMO do the headgasket and studs if you don't know their history.
Re: Head
Postby alltracman78 » Wed Jun 10, 2015 8:37 pm
You'll need the transmission attached to do a compression check, but you can do a leakdown test with the engine on a stand; as long as the timing belt is installed.
And yes, you can pull the head in or out of the car with the intake manifold on.
Not much sense leaving it on if the engine is out of the car though.
Re: Head
Postby 819_ay » Wed Jun 10, 2015 10:17 pm
Aright thanks a lot guys... What brand of headgasket do you recommend? And for head bolts arp I guess?
819_ay
Re: Head
Postby 819_ay » Wed Jun 10, 2015 10:35 pm
Timing belt is off the car... So can't do that... I guess I will go ahead and change it... Just makes sense since the engine is out and on an engine stand just wasn't planning and extra 300$ lol... Anyways it is what it is, I miss driving my gt4...can't wait to get it running... My turbo might be shot as well... I have a little side to side shaft play no front to back
819_ay
Re: Head
Postby klue » Thu Jun 11, 2015 1:12 am
OEM gen 3 gasket, or Cometic have served me well. ARP studs for sure dont mess around with oem bolts
Re: Head
Postby 819_ay » Fri Jun 12, 2015 9:31 pm
So I took the head off... And it smelled like ass... It smelled like the worst fart, "in the history of man kind, there was a little bit of coolant left in the block and when I poured it out it was brownish and milky... So I guess it is a good thing that I decided to changed the HG
819_ay
