Hard blip of the throttle, engine dies....
Postby smog7 » Fri Jul 03, 2015 9:20 pm
My st185's engine is cutting off when I clutch in after an aggressive throttle blip.
Rpms drop and engine dies.
How should I go about trouble shooting?
-omar
rally tarmac 1990 st185
smog7
Re: Hard blip of the throttle, engine dies....
Postby smog7 » Sun Jul 05, 2015 11:19 pm
And this is why I am no longer active on this forum.....
-omar
smog7
Postby Ugotgerms » Mon Jul 06, 2015 3:58 am
Mine used to do that, I cleaned my MAF, got new spark plugs and gapped them correctly, got a new rotor and cap and wires. I also replaced my o2 sensor. One or a combination fixed it. Does it happen when driving or in nuetral, because min was when driving
1993 Toyota Celica GT**SOLD**
1997 Mitsubishi 3000GT VR4 #255/510 **SOLD**
1992 Toyota Celica All-Trac
2001 Honda CRV LX
Ugotgerms
Postby smog7 » Mon Jul 06, 2015 5:11 am
Happens in gear and in neutral. Plug wires, cap and rotor are fairly new. Iridium plugs have about 30k on them, guess I'll check them out as well as the afm.
-omar
smog7
Postby MWP » Mon Jul 06, 2015 8:23 am
TPS would be my first check.
Postby Ugotgerms » Mon Jul 06, 2015 11:21 am
Thats right, I also readjusted the tps at the same time
2001 Honda CRV LX
Ugotgerms
Postby yyonline » Mon Jul 06, 2015 5:52 pm
There's a vacuum operated dash pot on the throttle body that's supposed to prevent the throttle plate from slamming shut. It will cushion it as it shuts. Might be worth looking into that as well as the vacuum line going to this in my car was in pretty sad shape.
yyonline
Postby smog7 » Mon Jul 06, 2015 9:49 pm
Thanks for the replies guys, going to check it our after my honeymoon to cancun :D :D
-omar
smog7
