Gen 1 3SGTE oil feel line
Postby hoys » Wed Jul 08, 2015 4:40 am
I've been fixing up this ST 165 and it has a pretty nasty oil leak on the turbo feed lines. Initially thought it was just the gaskets being bad (or non-existent as PO used RTV....). Replaced the gaskets and the leak was even worse. I've diagnosed it as the feed line before the turbo feed line assembly leaking. Is this a part I can still get? (I know, unlikely, going to check tomorrow) or how do I bypass this silly oil block?
Thanks!
hoys
Re: Gen 1 3SGTE oil feel line
Postby anothergt4 » Wed Jul 08, 2015 4:57 pm
Do you have a picture? It sounds like you may be talking about the oil cooler? I'm not sure you can just bypass it, maybe you could install a remote cooler? Is it the sardine can looking thing with a couple of "banjo" bolts through it?
anothergt4
Postby hoys » Wed Jul 08, 2015 4:59 pm
anothergt4 wrote:Do you have a picture? It sounds like you may be talking about the oil cooler? I'm not sure you can just bypass it, maybe you could install a remote cooler? Is it the sardine can looking thing with a couple of "banjo" bolts through it?
Yep, the sardine can looking thing. I've opted to use this:
Get a larger 18mm banjo to -4AN and possibly extend the drain to the oil pan drain.
hoys
Postby anothergt4 » Wed Jul 08, 2015 5:38 pm
Gotcha, if you want to try another cooler I have one laying around somewhere, you could have it for shipping, I've got quite a few parts just lying around that I'd rather go to someone needing them.
anothergt4
Postby hoys » Wed Jul 08, 2015 5:40 pm
If you have the lines as well I wouldn't mind it at all.
hoys
Postby anothergt4 » Mon Jul 13, 2015 7:34 pm
Could you pm me a number or email to send some pictures to, to find out for sure if I have what you need? Thanks
anothergt4
