St185 turbo boost gauge stuck - no vacuum TPS
Postby GT4ZBoy » Tue Jul 21, 2015 10:22 pm
Hi all,
My all trac just got an overhaul and he cam seals, timing belt, all hoses, replaced rack and pinion, new clutch etc.
Everything works fine so far except for the turbo gauge. It's stuck under 0 and won't move under boast. The turbo seems to boost fine but the gauge doesn't move at all. Is there a sensor t piece loose or broken?
Thanks
GT4ZBoy
Re: St185 turbo gauge not spooling after repairs
Postby underscore » Tue Jul 21, 2015 11:15 pm
I'd be looking at the pressure sensor, its plumbing and its wiring. Does it show vacuum at all or just sit at 0?
Postby GT4ZBoy » Tue Jul 21, 2015 11:39 pm
Doesn't show any vacuum at all. Once the car is started the needle moved a few notches up but not receiving any vac under boost :/
See attached pic
GT4ZBoy
Re: St185 turbo boost gauge stuck - no vacuum TPS
Postby GT4ZBoy » Wed Jul 22, 2015 11:18 am
Found this thread and will check the car at the shop tomorrow:
http://www.gtfours.co.uk/what/tps/tps.htm
I'll check the turbo pressure sensor...
GT4ZBoy
