91 ST185 ECU
91 ST185 ECU
Postby bluescapegoat » Sun Jul 26, 2015 4:25 am
I bought the car used, previous owner said a shop told him it needed an injector for cylinder #4.
I did a full tune up, had the injectors cleaned, and still running on 3 cylinders. We traced the issue back to the ECU, which isn't sending out a signal for the injector to pulse.
The current ECU in the car has an ATS rom tune, according to the previous owner. I have not removed the ECU yet to check.
Could the rom tune cause this issue?
If I get another 91 USDM ECU, can I swap the ROM chip to the new ECU to carry the tune over?
bluescapegoat
Re: 91 ST185 ECU
Postby tubasteve » Fri Jul 31, 2015 9:37 pm
Find the bad transitor aka injector driver
tubasteve
Re: 91 ST185 ECU
Postby ___Scott___ » Fri Jul 31, 2015 10:37 pm
Pull the ECU and inspect the solder joints. There may just be a cracked one that would explain the problem.
If the actual injector driver transistor is bad, it's not too hard to replace them. The hard part is finding a comparable transistor without knowing exactly what Toyota (Denso) used.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Re: 91 ST185 ECU
Postby Smaay » Mon Aug 17, 2015 2:03 pm
Also make sure you have 12V on one wire on the injector with the key in the on position. check continuity on the other wire to the ECU. Dont do surgery to your ECU if your wiring is bad
2001 Celica GT-S 2ZZ-GTE
90 Celica All-Trac 3S-GTE
97 Supra 2JZ-GTE
97 Celica GT 3MZ/1MZ hybrid
Smaay
Users browsing this forum: Baidu [Spider] and 2 guests
