165 won't keep idle and killing batteries
Postby 91Atrac » Mon Aug 03, 2015 6:11 pm
Anyone have ideas?
I've changed 3 alternators with no difference in idle.
Ideas please
91Atrac
Re: 165 won't keep idle and killing batteries
Postby underscore » Mon Aug 03, 2015 6:32 pm
Have you confirmed the charge is getting from the alt to the battery (it battery reading 14V while running)? The 100A charge fuse might be bad.
Postby 91Atrac » Mon Aug 03, 2015 7:02 pm
No I haven't. Don't know how to do that. I use a multimeter?
91Atrac
Postby underscore » Mon Aug 03, 2015 9:07 pm
Yeah when running the battery should be at the same voltage as the alternator output. Alternately you can measure the resistance between the battery positive and the alternator output, it should be a short between them.
Postby 91Atrac » Tue Aug 04, 2015 12:03 am
Alright. Tomorrow I'll give that a try
91Atrac
Postby 91Atrac » Thu Aug 06, 2015 3:53 am
Turned to be a faulty alt fuse. Was welded to the board and we replaced it a bit sobehow.
91Atrac
