Open Port On Valve Cover w/ Picture
Postby 1337computing » Tue Aug 18, 2015 9:40 pm
I just realized i have an open vacuum port on my valve cover, any know where it should go?
1990 Celica All-Trac Turbo ST185
3" Berk DP, 3" Straight Piped, Magnecor Wires, EBC+
1337computing
Re: Open Port On Valve Cover w/ Picture
Postby yotaboy93 » Tue Aug 18, 2015 9:58 pm
Its for the PVC system.There should be hose going from the valve cover back Into your Intake do you still have the stock air box?
yotaboy93
Postby alltracman78 » Tue Aug 18, 2015 10:47 pm
It goes to the throttle body. There's a port on the bottom next to the port for the FPR regulator.
Postby yotaboy93 » Wed Aug 19, 2015 12:16 am
Oops I didn't look at the picture I just assumed it was the PVC you was talking about ...sorry for the mis information
yotaboy93
Postby alltracman78 » Wed Aug 19, 2015 1:09 am
It's part of the PCV system. Just not the main port.
Postby 1337computing » Wed Aug 19, 2015 3:15 pm
Thank you!
1337computing
