Best rear diff and transmission oil?
Postby Rallly » Thu Sep 03, 2015 12:00 am
What brand do you guy's recommend for the rear different and tranny? I'm up in Canada and gets below -30 here so also what grades should I use?
Thanks!
Rallly
Re: Best rear diff and transmission oil?
Postby warracer » Thu Sep 03, 2015 12:15 am
Rallly wrote:What brand do you guy's recommend for the rear different and tranny? I'm up in Canada and gets below -30 here so also what grades should I use?
Thanks!
Im in the same area, and I'll get bashed for this but I use 80w90 Motomaster extreme pressure oil , rated for both api gl4 and gl5 (website says GL-5 only but on the gallon it says GL-4 and GL-5) , not ideal but I never had any issues in over 100'000km with it and its 27$ for 5liters , transmission shifts super smooth and never grinds.
Canadian Tire #28-0249
Link : http://www.canadiantire.ca/fr/pdp/motomaster-80w90-extreme-pressure-gear-oil-5l-0280249p.html
In the winter its heavy, so I always start the car with the clutch in (jdm cars don't have a clutch switch) then after 10seconds or so, slowly depress it and let it sit for 30sec after I drive <3000rpm until it reached proper engine temp, then I beat the crap out of it. :lol: Never had any issues in 4years of dailying the car in any conditions.
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby Rallly » Thu Sep 03, 2015 12:22 am
Thanks!
Thank you.for your opinion and info:)
I'm in North Bay, where are you?
Rallly
Postby warracer » Thu Sep 03, 2015 1:32 am
Im in northen Quebec, near Tremblant
____________
ST185H A-Spec:
warracer
Postby Rallly » Thu Sep 17, 2015 1:34 am
Any other tried and tested oils that eliminated the second gear random crunch?
Rallly
Postby zaluss » Thu Sep 17, 2015 3:16 am
I used this in the ST205 trans with great results.
http://www.amazon.com/gp/product/B000CP ... detailpage
zaluss
Postby Rallly » Thu Sep 17, 2015 10:20 am
zaluss wrote:I used this in the ST205 trans with great results.
Did you use it in the diff or trans or both? Is this designed for the st158 all-trac too?
Rallly
Postby quieter » Thu Sep 17, 2015 11:35 pm
75w90 is rated for colder temperatures if you compare it to 80w90 and its also more expensive. like Warracer said, as long as you dont beat it at cold starts you should be fine with 80w90.
2011 BMW 535xi M pack (daily)
-Simon
quieter
Postby Rallly » Fri Sep 18, 2015 10:16 am
Roms47478 wrote:transmission shifts super smooth and never grinds.
sbobet เล่นไม่ได้
What are you using?
Rallly
