how do you clean a maf sensor on st185?
Postby Soobierunner » Mon Oct 26, 2015 3:56 am
Hello world,
so, i have a maf sensor problem. now my car wont idle for more than a minute. i tried cleaning the maf out with maf cleaner. no luck. wondering if there is anything more i can do. i hear that the 3sgte have very sensitive sensor.
thanks.
Soobierunner
Re: how do you clean a maf sensor on st185?
Postby ___Scott___ » Mon Oct 26, 2015 1:15 pm
ST185s don't have MAF sensors. They have Air Flow Meters. There are no hot wires to clean in an AFM.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby timek1m » Tue Oct 27, 2015 3:20 am
Thanks for the response. So to clarify, there is no maf, but something called a afm. And it would cause problems like vacuum leak if broken?
So best solution is to replace and no fix. Thanks
1990 Alltrac
timek1m
Postby ___Scott___ » Tue Oct 27, 2015 3:45 am
I wouldn't say that.
The AFM is just a spring-loaded flapper (technically called a vane), connected to a variable resistor. They are pretty robust and not at all as temperamental as a MAF of any variety. It's possible that the resistive element could wear out and cause issues, but it's certainly not a common problem. If you can find one to borrow, that's worth trying, but I would be surprised if it actually solved the problem.
If you are having issues that are symptomatic of a vacuum leak, I would suggest looking harder for the vacuum leak.
Scott
SONY
___Scott___
Users browsing this forum: Bing [Bot] and 3 guests
