St185 and st185 afm (maf) sensor same?
Postby timek1m » Fri Oct 30, 2015 4:58 am
So is the maf sensor for the st185 and 165 the same? Need new maf for st185 and found one for st165. Wondering if it will work. Thanks
1990 Alltrac
timek1m
Re: St185 and st185 afm (maf) sensor same?
Postby FC Zach » Fri Oct 30, 2015 7:32 am
The AFM from each car is different. . Will it work, probably but they are not the same. Just like the NA FC3S RX7 AFM, it's the same shape, plug, and manufacturer with only a digit or two difference between the part numbers from the ST185 and I've heard it'll work as well but still, not the same.
If it helps. . I found I had been using the wrong AFM (22250-74180) that was installed by a previous owner and I had daily driven with this from Jan. 2013 up until last week. The incorrect AFM was from a ST162 3SGE.
What you need is part 22250-74200, you could search the junk yards if you have any close to you and find one off any 5th gen Celica no matter the model. . according to this site, they all use the same part. http://www.toyotajaxparts.com/toyota/celica/2225074200/1992-year/st-trim/1-6l-l4-gas-engine/electrical-cat/powertrain-control-scat
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby timek1m » Mon Nov 16, 2015 11:44 pm
Thanks, so much. Found a am and now. That didn't fix anything. I reset everything it idles at 1500 rpm. And then dies after 30 sec. I can't seem to locate any vacation leaks. I'm wondering if it might have to do with my safc.
So I had a blown turbo manifold gasket blew. So I replaced it. And then I started having this idling issue. So I was told it was the maf. And I replaced it. And no fix. There is no vac leak. Any ideas on what it might be?
1990 Alltrac
timek1m
Postby timek1m » Mon Nov 16, 2015 11:51 pm
1990 Alltrac
timek1m
