DeeCee":2ej3pka2 said:i stand corrected:
FC Zach":2szkh6dg said:No driving the AllTrac through high water!
Rallly":1omcobgc said:Is this diff vent able to be changed while on the car? Seems all that's left is a nut like flange attached to the remaining body of the vent. I think I could get a socket on but not sure if I should leave it or what?
Ghooble":y4ys88pu said:The whining is very likely the pinion preload being loose. Mine was basically nonexistent. I swapped a 205 rear diff and rebuilt it. No more whining.
