Electrical gremlins, engine retards when wet
Postby Killtodie » Wed Nov 18, 2015 4:40 pm
This has been happening most of the time. Whenever I drive over some large puddles (I dont have any undergaurds) my engine starts to retard the timing, and I cant get into boost. This lasts for a bit, and then goes away.
I first started noticing this when I was rinsing off an oil leak around the filter housing so I could trace it better. Everytime I washed the exhaust side of the engine, nor mater how careful I was, immediately after the car would bog down, and run like ass.
My question is, what could possible get wet there for this to happen?
I thought maybe the knock sensor, but its on under the intake side. Its possible that it gets wet from driving under a puddle, but not when I use low pressure water to rinse the exhaust side of the block.
I avoid getting any of the connectors wet, but I do hose off the water neck liberally. Anything there could cause this? I have EGR delete, I still have the BVSV in there, and anything else is just a sensor. Would anything there cause my issue?
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Re: Electrical gremlins, engine retards when wet
Postby 88gt4DE » Sun Nov 22, 2015 12:43 pm
Strange ... no CEL when this happens ?
Postby Killtodie » Sun Nov 22, 2015 4:50 pm
88gt4DE wrote:Strange ... no CEL when this happens ?
No.
Some of the wiring is old, tape peeled off, connection ends exposed, so I know something is shorting out, just trying to figure out what could cause the engine to retard timing, like its going in limp mode.
O2 sensor? Knock sensor? only two I can think off.
Killtodie
Postby Bempa » Sun Nov 22, 2015 4:54 pm
Have you checked is there is any stored fault codes?
AE92 4age 20v Engine rebuilding
KE70 4age 16v In progress
ST165 3sgte Brum Brum
ADT251 2ad-fhv Daily
AE92 4age 16v Bigport What to do with this one?
ACM20 1az-fe Wife´s daily
Instagram Benny_Gustavson
Bempa
Postby Killtodie » Sun Nov 22, 2015 5:04 pm
Bempa wrote:Have you checked is there is any stored fault codes?
No, same way to read normal codes?
Killtodie
Postby Bempa » Sun Nov 22, 2015 5:07 pm
Yes it's the same way
Bempa
