Cranks over but no spark or pulse of the injectors
Postby celicagts31 » Fri Nov 27, 2015 5:15 am
Hey guy I need some help I have no fuel or spark and I found out ecu wiring was spliced and so I fixed that and still nothing anybody have the same problem ? The engine is a st185 with a 165 setup for turbo
Sent from my One using Tapatalk
celicagts31
Re: Cranks over but no spark or pulse of the injectors
Postby msanders2 » Fri Nov 27, 2015 6:32 am
Check your main efi fuse.
msanders2
Postby celicagts31 » Fri Nov 27, 2015 6:44 am
Did and changed it still nothing
celicagts31
Postby ___Scott___ » Fri Nov 27, 2015 7:31 pm
Check your EFI relay. Remove it and bang it on something solid then put it back and try again. It worked for me once.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby celicagts31 » Fri Nov 27, 2015 7:41 pm
Ok lol
celicagts31
Postby msanders2 » Fri Nov 27, 2015 7:52 pm
do you have a check engine light when you turn your key to the on position and the dash lights come on?
msanders2
Postby celicagts31 » Fri Nov 27, 2015 7:53 pm
Yes I do
celicagts31
Postby celicagts31 » Fri Nov 27, 2015 8:05 pm
Like I've checked wiring and check the coils and wired up a new igniter
celicagts31
Postby underscore » Fri Nov 27, 2015 8:34 pm
Check your grounds on the ECU and engine, you can use jumper cables as temp engine grounds to see if that helps.
Postby celicagts31 » Fri Nov 27, 2015 8:43 pm
Ok awesome I'll try that with the ecu
celicagts31
