Oil leak help
Oil leak help
Postby Toyotaguy » Sat Dec 12, 2015 7:42 pm
I have a oil leak coming from behind my oil filter housing and I can't find but one of the seals behind the housing. The one I need before taking it apart is the bigger deal parts number 96732-31055 any may know a fix and somewhere that sells this seal. Seal is discontinued and I tried three different Toyota parts dealers
Toyotaguy
Re: Oil leak help
Postby Killtodie » Sat Dec 12, 2015 8:22 pm
15517-88380
96732-19019
http://stores.revolutionparts.com/toyotapartznet.com/
I just bought mine, but I wont be using them. Paid $13.
If you want, I can mail them to you for $10
This is for an ST165
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Re: Oil leak help
Postby Toyotaguy » Sat Dec 12, 2015 9:01 pm
I can get the 96732-19019 but can't get the 96732-31055. What's the 15517-88380?
Toyotaguy
Re: Oil leak help
Postby Killtodie » Sat Dec 12, 2015 9:50 pm
Toyotaguy wrote:I can get the 96732-19019 but can't get the 96732-31055. What's the 15517-88380?
Dont remember which is which, but one is a small size oring, the other is the larger size oring.
Killtodie
Re: Oil leak help
Postby Toyotaguy » Sat Dec 12, 2015 11:42 pm
I know the 19019 is the small one and the big one 31055 is the big one which has been discontinued.
Toyotaguy
Re: Oil leak help
Postby gtfour93 » Sun Dec 13, 2015 5:13 am
TOYOTA TEAM EUROPE
gtfour93
Re: Oil leak help
Postby Toyotaguy » Sun Dec 13, 2015 5:18 am
Does the st185 o-ring fit the st-165 cause my parts guys says they don't cross reference...
Toyotaguy
Re: Oil leak help
Postby Killtodie » Sun Dec 13, 2015 5:17 pm
Yup, those are the two that I bought for my ST165, let me know if you want those.
Killtodie
Re: Oil leak help
Postby yyonline » Mon Dec 14, 2015 12:42 am
Try 96732-31060 or 15517-88380 as a possible replacement for the discontinued o-ring. 96732-31060 is from an early ST185, and 15517-88380 from a later ST185. I have the big O-ring for the ST185 in my parts collection. I measured it and it's 65mm outside diameter, 3mm thick, if this helps any.
yyonline
Re: Oil leak help
Postby Toyotaguy » Mon Dec 14, 2015 1:06 am
yyonline wrote:Try 96732-31060 or 15517-88380 as a possible replacement for the discontinued o-ring. 96732-31060 is from an early ST185, and 15517-88380 from a later ST185. I have the big O-ring for the ST185 in my parts collection. I measured it and it's 65mm outside diameter, 3mm thick, if this helps any.
I appreciate the info I'll maybe just order the one for the st185 and see how they match up
Toyotaguy
Re: Oil leak help
Postby Nate165 » Mon Dec 14, 2015 5:52 pm
I have the same problem, and you just gave me an idea on what to check out.
Nate165
Re: Oil leak help
Postby Killtodie » Mon Dec 14, 2015 5:56 pm
Nate165 wrote:I have the same problem, and you just gave me an idea on what to check out.
I thought I had this as a problem, but it was massive blow by and oil was coming out the dipstick shaft, even after being secured down with a spring.
It looked like it was leaking behind the filter, but after very careful cleaning and observation it turned out to be the dipstick.
Killtodie
Re: Oil leak help
Postby Nate165 » Mon Dec 14, 2015 10:42 pm
How would you go about solving that? I'm still clueless
Nate165
Re: Oil leak help
Postby Toyotaguy » Tue Dec 15, 2015 1:55 am
I spayed down the area real good with brake clean started it let it idle up to temp with a little bit of throttle and watched to see where the was fresh oil. Which mine ended up being obvious since I could see it pooling around the filter housing.
Toyotaguy
Re: Oil leak help
Postby Killtodie » Tue Dec 15, 2015 5:38 pm
Toyotaguy wrote:I spayed down the area real good with brake clean started it let it idle up to temp with a little bit of throttle and watched to see where the was fresh oil. Which mine ended up being obvious since I could see it pooling around the filter housing.
Yeah, I power washed the engine bay, idled it, and looked for the leak.
If its a bad head gasket, or blow by, the leak will only happen under boost, so you should drive down the block at WOT, pull over, and look for leaks.
Killtodie
Users browsing this forum: Bing [Bot], Yahoo [Bot] and 2 guests
