Cannot select any gear
Postby hoys » Sat Jan 16, 2016 3:40 pm
Long story short, had two shifter cables fray or break, took awhile to order a new custom one, went to put it on last night and the car will not go into any gear, even when actuating the shift mechanism on the transmission by hand. Car sat for about four months, would go into gear just fine before.
Any ideas?
hoys
Re: Cannot select any gear
Postby 88gt4DE » Sat Jan 30, 2016 4:14 am
Does it go in gear when its not running ?
Postby hoys » Sat Jan 30, 2016 4:14 am
Nope.
hoys
Postby 88gt4DE » Sat Jan 30, 2016 4:16 am
Original problem was broken cable I assume. All working fine prior assuming. Which cable broke ? up and down or side to side ?
Postby hoys » Sat Jan 30, 2016 4:17 am
Up and down.
hoys
Postby 88gt4DE » Sat Jan 30, 2016 4:18 am
Does the shifter move at all or does it feel locked in place ?
Postby hoys » Sat Jan 30, 2016 4:19 am
Moves fine. Without the shifter cables connected I can't shift the trans at the bellcrank
hoys
Postby 88gt4DE » Sat Jan 30, 2016 4:22 am
So you cant even get the gears to change on the trans when moving the selector on the trans with the cables off ...
Postby hoys » Sat Jan 30, 2016 4:23 am
Nope. Like I said though it shifted fine before it was parked
hoys
Postby 88gt4DE » Sat Jan 30, 2016 4:24 am
Very strange ... does it roll or is it stuck in a gear ?
Postby underscore » Sat Jan 30, 2016 4:47 am
Does engaging the clutch pedal help at all?
Postby hoys » Sat Jan 30, 2016 4:48 am
Engaging the clutch does nothing (but I haven't confirmed that the hydraulic system still works) and the car isn't in gear, while pushing it the accessory belt doesn't turn.
hoys
Postby 88gt4DE » Mon Feb 01, 2016 2:21 am
If you cant change gears manually at trans its either internal or the part the cables attach to is messed up.
Postby Aaron » Sat Apr 09, 2016 10:07 pm
Clutch slave/master cylinder?
__________
Aaron
1992 ST185
1989 AE95 Wagon
Aaron
Postby hoys » Sat Apr 09, 2016 10:10 pm
Fixed this a bit ago. We had a bit too much to drink when we put the cables in and mixed the two up.
hoys
