Motor mounts
Motor mounts
Postby 819_ay » Fri Mar 11, 2016 12:13 am
I was wondering how to remove the engine mount bushings from the mounts, without damaging them.... If it's possible thanks
819_ay
Re: Motor mounts
Postby klue » Fri Mar 11, 2016 11:45 pm
819_ay wrote:I was wondering how to remove the engine mount bushings from the mounts, without damaging them.... If it's possible thanks
You would have to machine a press tool just the right size for the sleeve to be pressed out
Re: Motor mounts
Postby 819_ay » Sat Mar 12, 2016 1:17 am
Aright thanks Luke... Will try to find something just the right size to press it out..
819_ay
Re: Motor mounts
Postby CSAlltrac » Sat Mar 12, 2016 2:16 am
You can cut the sleeve then knock it out with a chisel.
Re: Motor mounts
Postby fastrax203 » Thu Mar 17, 2016 1:11 pm
http://www.mr2oc.co.uk/know-your-2-know ... bartid=160
Pretty much the same once the mounts are out of the car.
fastrax203
