alltrac vs celica wiring
Postby clayton351 » Thu Apr 28, 2016 6:34 pm
Looking at a car with some electrical issues. Are all the harnesses all trac specific or just the engine harness?
clayton351
Re: alltrac vs celica wiring
Postby aus jd 2703 » Thu Apr 28, 2016 10:56 pm
I can only speak for RHD but the engine harness and also the fuel pump and sender wiring are different.
for the most part judging by the wiring diagrams they are interchangeable.
a great example is I run a 184 cluster in my 185 no changes.
aus jd 2703
Postby Mr Alltrac » Fri Apr 29, 2016 3:43 pm
I would think the only big differences between the wiring harnesses would be options that your car came with.
The differences are slight but should still work. Electric seat controls, convertible windows, mirror vibrations, alarm systems, system 10 stereo. All these will just have a lack of or extra plugs you may not need. But the general body harness should be the same.
Mr Alltrac
