Suddenly rough running
Postby deepsky » Sat May 14, 2016 12:03 am
Hi Guys, it seems like I can't keep up with the problems on my 92. I can only keep it if it is a fairly reliable DD. Anyways, sorted lots of problems, and almost ready to start driving it regularly, and suddenly it just idles rough and stumbles under acceleration. Seems like its missing, but it seems more irregular. Tried different plugs, seems maybe a little better, but not sure. Also, while troubleshooting I found this set of 3 wires coming up from what seems like the bottom back of the engine, its a pink/red, yellow and black wires in a protective sheath, with what looks like the connector broken off. I cannot find anything not connected in the area.
deepsky
Re: Suddenly rough running
Postby yyonline » Sat May 14, 2016 4:12 am
It's hard to tell where that is. Can you take a less close photo?
yyonline
Postby underscore » Sat May 14, 2016 4:14 am
That doesn't look oem to me, my default check for bogging like that is a vacuum/boost leak.
Postby deepsky » Sat May 14, 2016 10:49 pm
In the photo you can see the brake lines on the firewall. I can't get any more of the wires in the frame. I agree this doesn't look oem. I would agree a vacuum leak seems likely, any ideas on how to find vacuum leaks? I haven't found anything yet. Thanks.
deepsky
Postby MacGyver » Sun May 15, 2016 1:59 am
Starting fluid. Spray sparingly around the lines. If the rpm pick up its getting in.
MacGyver
Postby deepsky » Sun May 15, 2016 6:08 am
MacGyver wrote:Starting fluid. Spray sparingly around the lines. If the rpm pick up its getting in.
Thanks for the tip, I'll try that.
deepsky
Postby underscore » Sun May 15, 2016 6:12 am
The easier way is to make a $5 tester, pressurize the system with the engine off and listen for the leaks.
