ST185 Engine Mount - Discontinued - Now What?
Postby 93celicaconv » Sun May 15, 2016 8:03 pm
I am doing a mechanical restoration on the drive train of my ST185 this spring/summer, ahead of a body restoration planned for this fall/winter. I ran into a part availability problem, could use your help.
I am changing all 4 engine mounts. I have 3 OEM (Toyota) mounts, but a 4th (passenger side) mount has been discontinued by Toyota (P/N 12362-74140). There doesn't appear to be any after market sources for this particular mount either. I do have a new P/N 12362-74120, for the ST184 coupe/hatchback (convertible has yet a different part number), but that mount is not identical (it may be interchangeable, but I see differences in the housing at least).
Just want to know if any of you have replaced your ST185 engine mounts recently and ran into the passenger side mount availability issue - what did you do? Has anyone used the 12362-74120 mount and, if so, how did it work for you? If you found an after market source, let me know the source and part number you used, and let me know if it is working for you. Would like to get this part issue resolved before starting the work process.
93celicaconv
Re: ST185 Engine Mount - Discontinued - Now What?
Postby zaluss » Sun May 15, 2016 8:17 pm
You have a couple of choices for aftermarket.
Xiiimotorsports
http://www.xiiimotorsports.com/index.ph ... g-kit.html
Brooks Racing (BRD) His personal car is a ST185.
https://www.facebook.com/Brooks.Racing.Dev/?fref=ts
I believe both of them can make a side engine mount with a varying degree of hardness.
zaluss
Postby yyonline » Sun May 15, 2016 8:57 pm
Get the engine mount from the 90-93 manual transmission convertible. It's the same as the ST185 RH mount, with one exception. You'll need to remove the top stud and replace it with the longer stud out of your old mount. The convertible mount has the same numbers molded into the rubber and everything. Toyota part number 12362-74200. Why the convertible got a special mount that's practically identical to the ST185 mount, when the GT coupe/hatch mount is different I have no idea...but there you have it.
yyonline
Postby yyonline » Sun May 15, 2016 9:02 pm
http://www.partsgeek.com/ss/?i=1&ssq=W0 ... 7&x=31&y=9
That's the convertible mount with a photo you can compare to your ST185 mount.
yyonline
Postby 93celicaconv » Sun May 15, 2016 10:47 pm
yyonline wrote:Get the engine mount from the 90-93 manual transmission convertible. It's the same as the ST185 RH mount, with one exception. You'll need to remove the top stud and replace it with the longer stud out of your old mount. The convertible mount has the same numbers molded into the rubber and everything. Toyota part number 12362-74200. Why the convertible got a special mount that's practically identical to the ST185 mount, when the GT coupe/hatch mount is different I have no idea...but there you have it.
I just looked up the application for 12362-74200, and that part number ties to the 1991-1993 5th Gen Celica Convertible, manual or automatic transmission. I have a fully restored 1993 Celica convertible, and just checked that mount, and sure enough, it looks identical except the stud for the stay is shorter on the convertible. What do you know, I had the answer to my own question without knowing it right in the garage.
Thank-you, YYONLINE, for your tip. I'll have to check if Toyota has 12362-74200 still available, I'm assuming the stud is threaded into the mount housing, so all I need is to double-nut the exposed thread of the stud (to lock the stud), then turn it out, right? If so, this will work great!
Wonderful forum here - great group of experts. May be asking more questions as I begin the mechanical restoration.
93celicaconv
Postby celica_gtx » Sun May 15, 2016 11:41 pm
Keep searching n be patient. Not to knock solid motor mounts but I pulled mine within a week for oem and kept my N-S solid. Less vibration will transfer to the car and be more pleasurable to drive. If ur going all track yea solids. And with N-S in the motor still doesn't move. I'm happy w my setup for my driving style. Just my 2 cents
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby yyonline » Mon May 16, 2016 12:17 am
If Toyota doesn't have them any more, the partsgeek.com site I linked has them in stock. I ordered one from there just based on the photo. I was curious if it matched the all-trac one or not. It was a factory item, in a bag with the Toyota sticker and all. So that's an option if Toyota's out of them.
yyonline
Postby ChrisD » Tue May 17, 2016 4:48 pm
Amayama.com lists it as available, $91.86 + shipping. Genuine Toyota.
Sent from my LG-H812 using Tapatalk
1988 ST165
1994 ST205 WRC
ChrisD
Postby yyonline » Tue May 17, 2016 11:29 pm
If you try to order it from Amayama, you'll get a message saying it's been discontinued. I tried awhile back.
yyonline
Postby aus jd 2703 » Wed May 18, 2016 5:48 am
Try 184 mounts that's what I'm running with out issue
aus jd 2703
Postby 93celicaconv » Wed May 18, 2016 10:41 am
There were 5 of the convertible engine mounts still available nationwide in the US, so I ordered one through Titus-Will Toyota parts (old 1stToyotaParts.com). Should arrive early next week. I intend to start the engine work next week also, so I'll advise how this convertible mount works, but I trust the swap of stay studs is the only adjustment I need to make to use the convertible mount.
93celicaconv
Postby 93celicaconv » Sun Oct 23, 2016 10:56 pm
Just a follow-up to this thread. Yes, the '91-'93 Celica GT Convertible RH engine mount is identical to the ST185 RH engine mount, except the stay stud is shorter, but the ST185 old mount stay stud was easy to remove and put into the new '91-'93 Celica Convertible RH mount. So this input was great. Not many of these '91-'93 Celica GT convertible engine mounts left out there anymore though.
93celicaconv
