Front Axle differences?
Postby Smaay » Sat May 28, 2016 3:59 am
are the front axles the same length? im finally putting my car back together and I cant get the right axle in. It appears to be way too long. The stub fits in the transmission, but its way too long to get it in the hub. and the outters the same length?
2001 Celica GT-S 2ZZ-GTE
90 Celica All-Trac 3S-GTE
97 Supra 2JZ-GTE
97 Celica GT 3MZ/1MZ hybrid
Smaay
Re: Front Axle differences?
Postby alltracman78 » Sat May 28, 2016 12:44 pm
Both sides are identical. The passenger side has an add on [slides on during assembly] vibration damper.
Aftermarket axles [most at least] won't even have the damper.
The inner joint might have come apart. They do that sometimes and can be a PITA to get back together.
Postby Smaay » Sat May 28, 2016 5:30 pm
thanks, i ran the part numbers from toyota and the outters are the same part number. I have done this a few times with no issues, I dont know why im having such a hard time with it now.
97 Supra 2JZ-GTE
Smaay
Postby yyonline » Mon May 30, 2016 10:16 pm
The axle shafts are the same length RH and LH. However, the stub that goes into the transmission is not the same between RH and LH. So if you have the wrong stub, you'll need to unbolt the stub from the axle shaft (6 hex key head bolts) and swap over the correct stub. Careful not to let the ball bearings fall out. They are a pain to get back together.
yyonline
Postby yyonline » Mon May 30, 2016 10:28 pm
Can you post a photo of what you have?
yyonline
Postby Smaay » Wed Jun 01, 2016 4:15 pm
my stubs were correct, i got it in. had to take the hub off.
97 Supra 2JZ-GTE
Smaay
